Tristar 406
Old Jan 19, 2021 | 02:24 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Tristar 406
Ok..long story short is that im active duty military and cirrently out of state for 2 months. I have a shop installing my tristar 406 dart shp motor. Upon inspection i was informed the lifters are hard to get in and it is taking about 50 ft/lbs to turn and around 45 ft/lbs to keep it turning. Oh and TriStar says i have to pay shipping back to them for them to inspect it. Has anybody ever had a bad experience with TriStar or is this normal? I have had nothing but bad luck with this car and thought a new engine would help....apparently i was wrong again.
Old Jan 20, 2021 | 10:33 AM
Car: 92 Camaro
Axle/Gears: S60 373
Re: Tristar 406
Nobody huh?
Old Jan 20, 2021 | 12:48 PM
skinny z's Avatar
Re: Tristar 406
Any details on how the rotation test is being done? Plugs in or out? Rockers lashed and operating the springs?
Can't comment on it being "hard to get the lifters in". Unless there's a mismatch somewhere. Need details on that too.
Old Jan 20, 2021 | 01:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Tristar 406
Dart blocks should have had the lifter bores honed to lifter spec. Some lifters may run smaller or larger than typical gm spec so lifter bore clearance greatly varies.
who knows what tristar did. As far as rotational torque that can depend on alot of things, piston to wall clearance, ring package/tension, bearing clearances, etc.
Old Jan 20, 2021 | 09:57 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Tristar 406
I don't know anything about TriStar engines; nothing good and nothing bad, so I have no helpful advice there. If they have a warranty issue, they may handle it for you, but I do agree that it does stink to have to pay shipping/freight.
Have you contacted DART with all the specs of the lifters and see what they say? As skinny and orr are very knowledgeable on engine components, I would hear them out a bit.
I'll keep following along; and I wrote back to your PM too. Feel free to reach out if ya need to
mcurry2885
Apr 10, 2010 07:03 AM
KamikazeIroccy
Mar 3, 2010 11:10 AM
Ozz1967
Jun 20, 2008 02:34 PM
no_car_yet
Aug 3, 2002 11:10 PM
Black Missile
Oct 8, 2000 08:26 PM
