Is there supposed to be vacuum here?
Old Feb 8, 2021 | 03:15 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hey everyone, I'm trying to track down a few issues and replace a few vacuum lines. Particularly a code 32 and no cruise control.
I found that I am not getting vacuum at this port. Is there supposed to be vacuum here? Its right above the goose neck.
Thanks in advance...
Old Feb 8, 2021 | 03:44 PM
Annihilate's Avatar
Engine: 5.0
Re: Is there supposed to be vacuum here?
I have also found I don't have vacuum at these two plastic lines either..
Old Feb 8, 2021 | 06:37 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The vacuum under the throttle body is ported vacuum. It only has vacuum with the throttle blades open. It gets used for the egr. One line goes back to the egr solenoid, the other line from the solenoid to the egr.
Old Feb 8, 2021 | 09:23 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Code 32 can be annoying, most of the parts like the EGR solenoid and temp sensor are discontinued for the F body’s so you have to source out with Corvette parts stores or used. If you get code 32 to flash only after cruising on the highway for a few minutes and have no drivability issues it’s likely the temp sensor on the outside of the EGR valve, that’s what it was on mine.
thatoneguy5x
Feb 10, 2013 03:24 PM
JetsterDajet
May 2, 2005 01:20 PM
chekbaka
Dec 2, 2004 05:45 PM
jfreeman74
Jan 18, 2003 05:44 AM
