Audio System killing battery, now car won't start cold
Old Jan 16, 2002 | 02:53 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I live up here in Pennsylvania, and its around freezing all winter long. I don't drive my car that much, so I start it every 2-3 days, if it will start. Sometimes the battery loses voltage, the starter cranks but then dies. I have to break out the jumper cables and jump it from my moms car most of the time. It is a prostart battery, I think the audio system might be killing it. I have a 300 watt amp w/ 8 inch bass tube. The lights dimmed, but I figured a .5 farad capacitor would settle that mumbo jumbo. It did, but the lights start dimming after 10 minutes of rumbling bass. SO what I am basically trying to say, is should I get a new battery, or will I just kill another one. It starts every 2 days, after that it gets tough to start, I haven't driven the car since early December, but I let it run 2 times a week roughly, so is it due to sitting? Okay I'll shut up now, let me know what you guys think.
~Mike
Attached Thumbnails Audio System killing battery, now car won't start cold-best-car-picture.jpg
Old Jan 16, 2002 | 03:01 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
First, stop calling yourself Pimp-whatever. Pimps are detestable people who ought to be put against a wall and shot!
You need a larger alternator. Period.
Try and get something in the neighbourhood of 100 amps. If the guys who sold you that audio gear know anything at all, they should be able to tell how much power the Alternator needs to put out for the gear involved. Call them.
Old Jan 16, 2002 | 03:10 PM
GreenProStreet's Avatar
I think that Jegs has a chrome alternator with a free 100 amp upgrade. Also you maybe want to invest in a quality battery charger. I bought one just after my 700 cca primo battery. The automatic ones you can set it ... and forget it!!!" (Bad infomercial)
Old Jan 16, 2002 | 03:49 PM
ChevyLuva3's Avatar
Yup get a new more powerful alternator. That or trade in all the sound system cr@p and get some performance mods.
Old Jan 16, 2002 | 03:56 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you are starting the car every few days and the battery is still dying then you have a short/bad alternator. The stereo will not drain the battery when the car is off, well it might if there is a short, but you probably have one else where. If you don't drive at all in the winter, add fuel stablizer, disconnect the battery and leave it until spring. Its not good to run the car for short periods and then shut it down. It needs to be driven or left alone.
Old Jan 16, 2002 | 05:48 PM
gmanuel's Avatar
Originally posted by Omega
If you are starting the car every few days and the battery is still dying then you have a short/bad alternator. The stereo will not drain the battery when the car is off, well it might if there is a short, but you probably have one else where..
make sure that the amp does get switched off when you turn the key to the off position
Old Jan 16, 2002 | 05:50 PM
mattRS's Avatar
systems
try getting a cap. you can get them at sound stores or best buy, circuit city, etc. they look like a REALLY big battery. they hold amperage so it doesn't kill your car so much.
Old Jan 16, 2002 | 05:57 PM
Patrick007's Avatar
He said he has a capacitor.. 1/2 ferrad.
Patrick DeGrosse Jr.
Old Jan 16, 2002 | 06:07 PM
mattRS's Avatar
my bad
sorry, didn't read his post well enough. my guess would be a bigger alternator
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
