88 TPI Why is it dying when slowing down
Old Mar 24, 2021 | 05:35 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
My problem is my 88 350 tpi keeps dying when I slow down or at slow speeds it will die. When it dies the rpms just fall to 0. Sometimes the rpms will bounce and then die. It will not die if you are idling in park. To start it back up you just put it in neutral and it will fire right back up wont die until you slow down again. A put it in a shop for the last couple of days and they could not figure it out. He said for sure- There is no vacuum leaks.
fuel pressure is good
tps is set correct
reset the idle correctly park 700rpms fans cut on it does to 900. In drive 600rpms
no check engine codes
new parts - TPS, IAC, 02 sensor, MAF, fuel filter, collant temp sensor, removed cat.
It does feel like it has a miss every once in a while but I don't know if that is related.
Any ideas?
Old Mar 24, 2021 | 06:10 PM
Kincer's Avatar
Car: 1989 Trans Am
Engine: 305 H.O. TPI
Transmission: Auto 700R4
Axle/Gears: 3.42 posi
Re: 88 TPI Why is it dying when slowing down or taking foor of accerator
Will be following this, my TPI 305 is doing something similar.
Old Mar 24, 2021 | 06:48 PM
Engine: 5.7 L98
Axle/Gears: 3.77
I have noticed just sitting in park when I press on my brakes the rpms go down and back up a little. Is that normal for the brake booster to pull the rpms down?
These are two videos of me just putting it in drive and reverse, letting the car push its self and me pressing the brakes
https://youtube.com/shorts/QJrSBLQ76Hk
https://youtube.com/shorts/qMHSKq2SXhQ
Old Mar 24, 2021 | 08:01 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
You’ve replaced most of the usual subjects and fuel pressure is good, have you checked out the injectors? And my only other idea is maybe something going on with ignition (distributor pick up)
Old Mar 24, 2021 | 08:17 PM
Engine: 5.7 L98
Axle/Gears: 3.77
I haven't checked the injectors or distributor yet.
Old Mar 25, 2021 | 08:31 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Yeah I am going to go ahead and install a new accel distributor cap and rotor, accel plug and wires and see if that does anything. If not I will start pulling injectors.
Old Mar 25, 2021 | 09:01 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Might be your MAF. When your throttle is very low or idle it surges/dies?
Old Mar 25, 2021 | 09:55 AM
Engine: 5.7 L98
Axle/Gears: 3.77
The idle just falls too low and bottoms out. It tries to catch it but it dies. I put two videos of it on here. MAF is new
Old Mar 25, 2021 | 10:07 AM
Engine: 5.7 L98
You could also try ohming the injectors with the engine warm to test their voltage, plenty of threads on here about that.
Old Mar 26, 2021 | 06:49 AM
Engine: 5.7 L98
Axle/Gears: 3.77
OKay i am also going to try that this weekend. Could it be the injectors if it doesn't do it unless I am going slow
IROCtometal
Jan 25, 2012 11:51 PM
Trinamo
Sep 6, 2009 06:12 PM
98formulaLS1
Apr 3, 2008 07:36 PM
89IROCZTPI
Oct 7, 2004 08:51 AM
dave89gta
Mar 7, 2003 06:01 PM
