Need some tips for a new car, PROBLEMS!
Old Apr 1, 2008 | 09:41 PM
98formulaLS1's Avatar
Car: 1998 IROC-Z
Engine: 5.7L 350ci
Transmission: 700R4 Auto
Well guys, this is my first post on this forum. So, please work with me here, lol.
I just got an 88 IROC-Z with a 5.7L. It wasnt running, bad fuel pump. I had it running with starter fluid. Now that I've replaced the fuel pump, it will actually start on it's own. BUT, I have to give it gas. It won't idle well at all. It doesnt die immediately, but it the RPM's will just for a few seconds and then die out. I suspect there may be some open vaccum connections, but I don't know where all the vacuum tubes are.
If anyone can offer any advice, links, things to check that are common problems, this would help.
Thanks!!!!!
Old Apr 1, 2008 | 10:36 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Need some tips for a new car, PROBLEMS!
welcome aboard, is it a tpi tbi carb? go on www.google.com put in 350 chevy engine vacuum diagram should pull 1 up. if its tpi pull the throttle body off and pull iac off and clean the passages for the iac also go to the homepage go in tech articles to iac and tps adjustments. hope this helps, later jimmy
Old Apr 1, 2008 | 10:48 PM
Car: 1998 IROC-Z
Engine: 5.7L 350ci
yes, its a TPI. Were there any other 350's produced in 88 that were NOT TPI's?
I will clean up the IAC and TPS. I'm get back here and let you know how it worked. thanks.
Old Apr 1, 2008 | 10:57 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
no they were all tpi but some people switch to carb
Old Apr 1, 2008 | 11:04 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
350s didnt come out until 86 all 85 were 305 you sure its a 350?
Old Apr 1, 2008 | 11:19 PM
Car: 1998 IROC-Z
Engine: 5.7L 350ci
not to sound like a smartass, but did you even read the thread? nowhere does it mention that I own an 85, its says 88 a few times already.
Please try and conserve forum bandwidth by reducing unnecessary posts.
Old Apr 1, 2008 | 11:23 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
my bad!!!!!!!!!!!!
Old Apr 1, 2008 | 11:34 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
I'm having the same issues though on my 87 350 iroc but it didnt start till i took out the bosch+4 spark plugs that were installed when i got it changed the wires and changed the cap and rotor. Is your EGR blocked off or its filter dirty? How bout the fuel filter? I cant seem to find where my problem is cause it goes away after the car warms up, im not running any smog junk and im pretty sure all vacumn hoses are hooked up except when i bought the car it had a bunch of hoses plugged up and missing the purge canister though it ran great, was actually running a 14.50 with just freemods.
Help us out guys, i missing my Roc and am thinking about just selling the one i have and start over but ive put so much money into it and its made me smile so much
Old Apr 1, 2008 | 11:45 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Sell that piece of junk to me and you won't have any problems with it starting anymore.
Old Apr 1, 2008 | 11:49 PM
Car: '87 Iroc-Z
its not a piece of junk by far. but how much you talk?
Old Apr 2, 2008 | 12:04 AM
Car: 1998 IROC-Z
Engine: 5.7L 350ci
i think he was talking to me, lol
Old Apr 2, 2008 | 12:54 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Make sure your CTS is plugged in/working. If the ECM thinks you're at -256 degree F (or whatever it things when it's unplugged) it will not run on its own unless you literally hold the throttle open but it will NOT stay running.
Ask me how I know.
Old Apr 2, 2008 | 09:14 AM
Car: '87 Iroc-Z
i do need a new CTS
Old Apr 2, 2008 | 09:27 PM
91chevywt's Avatar
So how old is the fuel in it? Since it sounds like it probably sat for a while. Old fuel will make anything run like garbage, even if you try to dilute it with fresh gasoline.
Old Apr 3, 2008 | 07:36 PM
Car: '87 Iroc-Z
its running okay now
rocn7roc
Sep 21, 2021 02:16 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
