New crate engine not running properly
Old Mar 28, 2021 | 09:08 PM
Ozzy1992z28's Avatar
Car: 1992 z28
Engine: 305 tpi
Hi guys.
long story short i have replaced the old 305 tpi in my 92 camaro with a zz6 crate enginge toped off with a first tpi intake and a cutom prom tuned for the new engine via specs i emailed to the guy. I started it but could not get the timeing right even though it idles smoothly the timeing looks like 60 degrees and when i turn the engine off and start it again it needs adjustment to idle smooth again. So i got a new exaust put on as the old one leaked and asked the mechanic to have a look. He had the same issues and said it seams to run well when cold starded but gets rough when it gets hot and after 3 min of idleing the headers are glowing so maybe running lean.
Any help would be appreciated as im so close to the finish line with this car
Old Mar 28, 2021 | 09:58 PM
GeneralDisorder's Avatar
Re: New crate engine not running properly
E-tuning may not be appropriate for that combo. But you need to properly resolve the timing question before you can know.
60 degrees seems highly unlikely (and have a smooth idle anyway). Probably wouldn't run. Double check your timing marks and your timing light setup.... and that you are triggering off cylinder #1 (driver's side front).
Glowing headers is either lean or timing is heavily retarded.... you sure you are on the correct side of the timing scale?
GD
Old Mar 28, 2021 | 10:22 PM
Car: 1992 z28
Engine: 305 tpi
Thanks for the reply
I am stumped buy the timeing issue, im not a qualified mechanic so i asked the mechanic doing my exaust to have a look and he thought maybe a dyno tune would solve the problem as he set the distributer to TDC and got the same issue i had. Would you recomend getting it dyno tuned to see if that helps?
Old Mar 28, 2021 | 10:31 PM
Yes. If it's something mechanical then very likely the tuner will be able to troubleshoot it before or on the dyno. That happens a lot and we do a LOT of troubleshooting on my dyno.
GD
Old Mar 29, 2021 | 06:53 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Is the est bypass connector being disconnected when the timing is being set?
Old Mar 29, 2021 | 09:04 AM
Car: 1992 z28
Engine: 305 tpi
I dont think he had it disconnected when he was setting the timeing. I mentioned it to him though so he might try to set the timeing with it disconected.? Do you think it could be the idle air control? I dont think it has been reset since moving it from the original intake to the new intake
Old Mar 29, 2021 | 09:46 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I would have the timing properly set before doing anything else.
Old Mar 30, 2021 | 05:54 PM
Car: 1992 z28
Engine: 305 tpi
Once i get it back ill try and set the timeing properly with the esc switch disconnected. Hopefully that works. All the mechanics in my area seem to work on modern cars and i seem to have to mention how to do things. Even finding someone to get it dyno tuned is a problem.
Ozzy1992z28
Jul 29, 2019 10:02 PM
aldixie
South Central Region
20
Apr 10, 2007 07:55 AM
Detroit_Z28
Mar 27, 2007 04:08 PM
CogsRS
Aug 12, 2004 06:01 PM
