Won't start
Old Apr 12, 2021 | 02:09 PM
Joshscamaro's Avatar
Won't start
I have a 1983 305 Camaro. I put a new rotor /distrubtor cap/ ignition coil/spark plugs and spark plug wires and now the car won't start. Any info on why and how to fix would be appreciated.
Old Apr 12, 2021 | 02:52 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Won't start
Prior to ^^^^this work, did the car start/run?
Old Apr 12, 2021 | 02:53 PM
Re: Won't start
Yes
Old Apr 12, 2021 | 03:00 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Re: Won't start
Yes
In that case, backtrack what you've done until you find your problem. Just a guess, but the first thing I'd do is replace the new coil with the the original and see if the new one is at fault.
Old Apr 12, 2021 | 03:35 PM
Re: Won't start
K. I will try this and T.Y. for the help.
Old Apr 26, 2021 | 01:11 PM
Re: Won't start
I put a different ignition coil on/ distrubtor cap/ rotor cap and spark plugs. It still won't start.
Old Apr 26, 2021 | 05:58 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Won't start
Check for spark at the plugs, if that doesn't work check for spark coming from the coil.
BOSS HOGG LOU
Jan 2, 2013 10:32 AM
PUNISH3R
May 18, 2012 02:36 PM
raiders8498
Mar 4, 2007 08:50 PM
BMF
Feb 20, 2004 07:24 PM
