Starting problems
Starting problems
So I need help figuring out my problem if anyone has an idea of what it is. When I turn my key my fuel pump doesn’t engage and my starter will not engage either. When I turn the key to start the car the brake light comes on. No security light though. Brand new starter and fuel pump. Please help
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Starting problems
When you open the door, do you get interior lights? when you key the car on, do you have the normal key on power items?
