Recommendations on Rear Main Seal
Old May 5, 2021 | 07:00 AM
ResIpsa's Avatar
Car: 1987 Formula 350
Engine: TPI 383 Stroker
I am in the process of replacing the rear main seal on my 383 (one piece). I have noticed that the prices run from as low as $15 to almost $100.
Honestly, I am fine paying a premium if it means that it won't leak and will last. Do you guys have any suggestions on which seal I should use based on actual experience?
If so, part numbers would be great. Thanks in advance.
Old May 5, 2021 | 10:58 AM
GeneralDisorder's Avatar
Re: Recommendations on Rear Main Seal
Go with a Viton (usually brown) seal. The PTFE seals will cause grooves in the crankshaft over time in my experience - requiring a sleeve eventually. The Viton seals stay soft forever unlike Nitrile. Silicone is too soft and easily damaged.
GD
Old May 6, 2021 | 07:24 AM
Vader's Avatar
FKM (Viton® if you happen to be a shareholder) can be a good choice, but limit that to 70-A durometer to prolong seal life. The seal design is also important, and a dual lip seal with leafs is a fairly safe choice for the application.
Old May 6, 2021 | 12:45 PM
ResIpsa's Avatar
GD & Vader I appreciate the responses and have found a Enginetech Viton seal and ordered it (actually 2 in case I screw up the install).
However, they were cheap (no more than the rubber or PTFE) I am not necessarily committed to using those seals. if you can point me to specific brands you have experience with I would still appreciate it (and then may have some extra viton rear main seals if anyone wants them for shipping cost only.
Sorry...I need to read a little better. I will check out the FKM seal. Wait FKM is just the Xerox copy machine (get it) of Viton...
Old May 7, 2021 | 03:18 PM
y5e06's Avatar
Car: itsa '85 LG4 S/E Turd 'Bird
Engine: Wheezy 305
Axle/Gears: 10Bolt, 3.42s, TruTrac
the listed seals changed somewhere in the mid '90s. The crank and housing, of course, are the same but the seal was revised. I believe they are the brown multi lip ones, i never bother with searching for teflon.
I just choose a vortec '98 OBS truck when using a parts selector.
Old May 24, 2021 | 08:27 AM
ResIpsa's Avatar
Rear main seal is installed. I did learn some thing however, if you remove the rear main seal aluminum housing do not install the seal into the housing before re-attaching it to the block. That prevents the Seal from expanding enough to get over the end of the crankshaft and causes the internal spring to pop out. After a couple failed attempts I ended up damaging the rear main seal.
After that I change my tactics and installed the rear main seal housing first and then evenly pressed the rear main seal over the crank shaft and into the retainer. Success!
I’m glad I Purchased two rear main seals...
BADMAN
South Central Region
Mar 10, 2009 08:21 PM
Johnny Blaze
Jul 28, 2005 08:55 AM
ChevyRacer
Jun 17, 2005 07:23 PM
SMURFN' Z28
Jan 5, 2005 10:42 AM
ChevyCamaro4lif
Dec 25, 2003 05:24 AM
