RE: 91 RS w/Pulse and Spark - No Start?
Old Jun 15, 2021 | 07:43 AM
scarello's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305ci
Transmission: 4-Speed Auto
1991 RS Vert with 305 TBI w/700r4
Car sat for a year or so - but ran when parked.
Initial issue was a bad fuel pump, which was addressed with a new tank and fuel pump. Rear fuel filter was changed as well.
Condition: When you turn the key, you can hear the fuel pump kick on and working. Injectors are pulsing and squirting fuel into the TBI but the car just turns over and never catches. Now if I go old school and hold the butterflies open with a screw driver, it starts to catch but only stumbles for like 5-15 seconds and never full catches or starts. PCV checked out out. We also cleaned out the IAC part of the TBI before replacing the IAC, as well as the TPS.
Changed: Coil, IAC, TPS, Distributor Module, Cap, Rotor, Wires and Plugs - same issue. The relays on the driver's side firewall were also relatively recently changed.
Thoughts?
Thanks!
-sc-
Old Jun 15, 2021 | 10:16 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 91 RS w/Pulse and Spark - No Start?
How about the pressure regulator? If there is flow but not pressure it might just pop and stumble.
Old Jun 15, 2021 | 10:46 AM
scarello's Avatar
Engine: 305ci
Thanks - I'll check that out.
Looks like it needs to be 9-13lbs.
-sc-
Cam_RS
Jul 7, 2014 08:38 PM
Tijoz
Aug 4, 2012 02:11 PM
chevycamaro91rs
Jun 25, 2011 06:24 PM
chevyz71man
Jul 3, 2006 11:03 AM
firechicken_3
Nov 9, 2004 09:37 PM
