Replaced fuel pump but still won't start?
Old Jun 24, 2014 | 06:41 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Transmission: 5-SPEED
Okay, whenever i tried to start the car but it would only crank. The car wanted to start and gets a slight idle only if i step on the gas pedal while cranking the car, then if i let go of the key while stepping on the gas pedal car would die in 3 seconds.
I know the car is getting spark, which its got a new spark plug, distributor, ign coil, cap, rotor and ign module. I really need help on this guys..
91 Camaro RS TBI
Old Jun 25, 2014 | 06:21 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Re: Replaced fuel pump but still won't start?
Anyone?
Old Jun 25, 2014 | 07:11 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Does the fuel pump prime for 3 seconds when you turn the key to "on"? Did you replace the fuel filter and strainer? I had to put 5 gallons of gas in my tank and cycle the fuel pump several times before my 305 started after changing my fuel pump.
Old Jun 25, 2014 | 09:27 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Right, i can hear the fuel pumps pitch noise for 3 secs. The new fuel pump came with a strainer. I havent changed the fuel filter just yet but im going to do that. I'll take your advice about adding 5 gal of gas and see what happens. Thanks!
Old Jun 25, 2014 | 09:39 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Check for fuel at schrader valve. Buy a Haynes manual and follow the procedures in the troubleshooting section.
Old Jun 29, 2014 | 07:41 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
I have replaced the fuel filter and added 4 gal of gas, and cycled the new fuel pump but still won't start? I noticed both injectors aren't firing, but one of the injector drips a tiny amount of fuel into TB and the other injector does nothing.
Tested both injectors with multimeter and resulted 2.4 ohms which they're okay?
I don't know what else could be the problem?..
Old Jun 29, 2014 | 12:51 PM
antares57's Avatar
My TBI injectors on my running thirdgens are in the 1.1 - 1.3 ohm range.
Old Jun 29, 2014 | 08:41 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Antares57 so are they both firing? If so, what else could b the problem on mine?
Old Jun 29, 2014 | 11:21 PM
antares57's Avatar
The injectors should have a conical spray pattern when firing. If one is dripping and the other is not doing anything then the injectors may be clogged or the coils in them may be bad anyway. Try starting the engine by spraying starting fluid while cranking and see if it wants to start. If it starts and dies then it's not getting enough fuel from the injectors and they may have to be replaced.
Old Jun 30, 2014 | 03:26 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Yes, the car does start when I spray starting fluid then dies after a few sec.
Old Jul 5, 2014 | 08:29 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Help anyone, both injectors are not firing. I've already cleaned them and tested them with ohm meter reading 2.4 ohms?
Old Jul 6, 2014 | 08:38 PM
rknm88's Avatar
HI. I have a 91. Did similiar... Was running, stalled, I was VERY low on gas.. 4 gallons in tank now... I can get to run, but the fuel pump will not start.. I get NO voltage in the run position... I get voltage for 2 to 3 seconds upon key up... Frustrated.. 3.1 v6... 91...
Old Jul 7, 2014 | 05:47 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Tested both with a light bulb, I get no pulse on both injector connector plugs. Both injector fuses are new, so i'm out of ideas on what to diagnose next?
Old Jul 7, 2014 | 09:58 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Are you getting spark?
Old Jul 7, 2014 | 08:38 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Car is getting spark, i replaced whole dist assembly
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
