Edelbrock heads help with valve seals
Old Jun 22, 2021 | 11:04 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
So after trying some different valve seals on a old set of edelbrock rpm 6071 heads I cannot find which valve seals to use. I am pretty sure it requires some kind of ribbon style valve seal and after doing some research found part number edl9758 as the number. So I ordered a set from summit as edelbrocks site said out of stock about a month later finally got them and they are just a regular set of umbrella style valve seals same as the felpro ones I tried before. Anyone know what would fit the valve guide outside diameter is .5290in inside diameter .3425 inch and valve stem is .3415
Old Jun 22, 2021 | 11:05 PM
C305's Avatar
Car: 91 camaro vert
Re: Edelbrock heads help with valve seals
Old Jun 23, 2021 | 09:50 AM
Use Comp Ccams 503-16
Old Jun 24, 2021 | 12:04 AM
C305's Avatar
Car: 91 camaro vert
Wow can't believe my local auto parts store was able to get the last pack of those by end of the day. I had to wait 7 weeks for the wrong edelbrock part number ones from summit. I installed 1 of them lightly tapped it down with a socket they look like a good fit. Thanks alot
Old Jun 24, 2021 | 09:42 AM
Giving your measurements made it eeeeeezy.
Locherle
May 16, 2021 02:37 PM
StealthElephant
Jul 28, 2004 10:54 AM
CamaroFreak87
Feb 29, 2004 06:36 PM
rpettway
Feb 11, 2001 02:08 AM
