Oil pump pickup clearance ok?
Old Jun 26, 2021 | 05:40 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I've had my motor together for a few weeks but have been double checking things. One thing I wasn't certain about was the oil pickup clearance. I used clay to set it but never liked how it was angled/positioned and did a best comprise for levelness.
The pickup is level with the bottom of the pan and is slightly above the oil drain hole.
I've read 3/8" clearance. Obviously I have more than that. I've also read clearance at least same as diameter of pickup.
I'm using a 1997 block/pump/pan. 3/4" pickup tube.
Pan is bolted down and picked is welded to the pump. But I'll take it apart and fix if needed.
Old Jun 26, 2021 | 06:38 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Oil pump pickup clearance ok?
The oil drain is also lower than the bottom of the pan by about 1/4" or so.
Old Jun 26, 2021 | 09:52 PM
NoEmissions84TA's Avatar
Old Jun 27, 2021 | 09:46 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I took the pan off. Cut the tack weld on the pickup and adjusted.
3/8" at the back, 3/16" at the tip, 5/8" to the screen.
HawkZ28
Aftermarket Product Review
Aug 11, 2022 05:06 PM
Hello, Michael
Apr 4, 2015 01:18 PM
Jaime-TA-84
Apr 10, 2012 08:23 AM
AmorgetRS
Apr 16, 2009 06:21 AM
GTAman
Aug 15, 2004 04:10 AM
