1991 305 tbi timing
Old Aug 7, 2021 | 08:31 PM
matt12ar's Avatar
Car: 1991 firebird
Engine: magflatoVE
Axle/Gears: magflato
1991 305 tbi timing
just picked up a 91 firebird when im in drive at a stoplight or drive thru i can feel random misfires and the tac dips slightly as its misfiring. Checked timing just now and discovered the timing mark is at the 1:30 gm truck position rather then the above the water pump mark, can the car even run with it being 40 degrees off like that?
Old Aug 7, 2021 | 08:48 PM
Re: 1991 305 tbi timing
can the car even run with it ...
Is it running?
Yes/no
Yes: it obviously can.
No: maybe not.
Put it where the car runs the best. EFFF abuncha "spec" and "book" and "mark" and "light". Especially when YOU ALREADY KNOW the whole "mark" system is fornicated.
If it RUNS good, it IS good.
That's all you need to know.
Old Aug 7, 2021 | 08:55 PM
matt12ar's Avatar
Car: 1991 firebird
Engine: magflatoVE
i want to get rid of the random misfires at stoplights, i ask about the 40 degree because i find it strange its that far off and can still run
Old Aug 7, 2021 | 08:56 PM
I should mention, first thing I'd look at for a "random misfire", is the spark plugs. Put in NEW ones. Not, "check"; not, "PO said she just changed em"; not, "they look fine"; NOT NOT NOT NOT NOT NOT NOT NOT. Put in new ones..
"Timing" won't create a "random misfire". Spark plugs will. Use logic and focus your mental energy where it can actually work.
See my signature for some help. "Timing" is NOT an "explanation" that fits ALL the facts for a random misfire.
Old Aug 7, 2021 | 09:03 PM
matt12ar's Avatar
Car: 1991 firebird
Engine: magflatoVE
just put in acdelco plugs,new cap rotor and wires
Old Aug 8, 2021 | 08:08 AM
Somehow I just KNEW that was coming...
So, since you did it AFTER it began misfiring, did it fix it?
BigLou907
Jul 12, 2012 10:55 AM
xRIPPINx
Jun 30, 2011 11:02 PM
racersedge1821
Feb 19, 2010 10:36 AM
Aarons92Maro
Feb 25, 2009 03:25 PM
wasp
Mar 2, 2003 12:39 PM
