Ways to get rid of Oil Smoke......
Old Jan 18, 2002 | 10:21 AM
camaro6spd's Avatar
I know this looks similar to the other post but I am just looking to see what you guys have used and your results.
Old Jan 18, 2002 | 03:59 PM
ede's Avatar
ede
fixthe problem and not try to mask it with a cure all in a can
Old Jan 18, 2002 | 04:01 PM
rezinn's Avatar
Discover a new oil that burns clear.
Old Jan 19, 2002 | 06:01 AM
ede's Avatar
ede
actually synthetic tends to burn clear, or not as noticable as dino juice.
Old Jan 19, 2002 | 12:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fix the car.
Usually that means valve guide seals.
Old Jan 20, 2002 | 08:20 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Switch to synthetic oil if you haven't already regardless if it smokes or not.
Old Jan 22, 2002 | 04:27 PM
camaro6spd's Avatar
I just need the engine to get me to Summer.....if you read the sig you will find out why....
Old Jan 28, 2002 | 02:28 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
do you mean all the time or just on start up? if its just on start G.M. has a revised v.guide seal that WILL stop it. they should have put the fu--ing things on from the get go but thats the deal.if you are smoking all the time, aka blue cloud special-you be s.o.l. the seal kit part# i have is 12511890 seeya
Old Jan 28, 2002 | 12:55 PM
camaro6spd's Avatar
Start up, and hard accel and decel.
Old Jan 28, 2002 | 02:55 PM
IROC57TPI's Avatar
Heres an old used car lot trick.....
Go to any place that sells chainsaws. Get a gallon and a quart of smokeless chainsaw oil in the heaviest weight you can find.
It'll never smoke again until the oil is changed.
Old Jan 29, 2002 | 11:09 AM
camaro6spd's Avatar
Yeah, well i it does not pass then I will do the valve seals.....I am running Valvoline 50wt with oil thickener..... It Still smokes , Hopefully this guy i know will pass the thing untill....I can't wait untill the new engine goes in.
Old Jan 29, 2002 | 08:30 PM
camaro6spd's Avatar
It was a no go....Operation Valve Seal Installation has an ETA of Sat. Feburary 2, 2001 @ Memorial High School Auto Tech department(were my father teaches). Umm he bought the seals and he got umbrella and o ring seals....oh well as long as they last thoug the summer while I build up the new 305....
Old Jan 29, 2002 | 09:33 PM
Chevy83Z28's Avatar
I've been advised against switching to synthetic oil on high mileage engines, because the oil is thinner and can pass through smaller gaps (mainly the piston rings) that the heavier oil can't, and will cause you to burn more oil and hurt performance. Is this true or not, because many people on this board say it's always good to switch.
Old Jan 30, 2002 | 01:03 AM
its true-if you have a motor with 30-50k (rough guess)switching to a synthetic oil will probably make a leaker out of what was previously a tight motor. its not really because its lighter viscosity, but, i understand it to be that the actual molecules that make up the stuff are much smaller than what is found in conventional oil. and they kind of slip thru the cracks be it gaskets, rotating shaft seals, valve guides,etc. seeya
Old Jan 30, 2002 | 03:46 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
Baloney!
Old Jan 30, 2002 | 05:03 PM
Chevy83Z28's Avatar
I'm not sure if its true or not, but it makes sense to me that as engines get more and more miles on them, the rings will get in worse shape, and the valve seals will detiororate a bit, and that switching to a lighter oil may help it to seep through these tiny holes, where-as heavier oil won't be able to. So giovanhalen, why do you say balony? Please support with evidence...
Old Jan 30, 2002 | 05:16 PM
SoCo80p's Avatar
you've just got classic old tired engine syntrome, time to rebuild! if its smoking when your gunning it thats blown rings and at startup thats the heads, time to eather pull the engine or sell the car.
Old Jan 30, 2002 | 05:54 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
The oil is not thinner that is why. If it is 30 weight then it is 30 weight. It will not leak or burn faster than conventional oil.
Old Jan 30, 2002 | 09:10 PM
Chevy83Z28's Avatar
So then what makes synthetic oil better? Sorry these are such... silly questions but I guess I don't know much better and am tryin to learn :hail: hehe... thanks guys.
Old Jan 30, 2002 | 10:22 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
It can withstand higher temperatures, it flows better at very low temperatures, higher film strength, you don't need to change as often because it doesn't break down as fast. If your conventional oil gets too hot it will cook and leave deposits and when it breaks down it wont have the film strength it should have. Checkout the thread titled everything you want to know about oil started by RX7 on this same page.
Old Jan 30, 2002 | 10:28 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
It is titled all you want to know about oil by RX7speed. No synthetic oil doesn't burn clear it burns blue but it takes alot higher temperature to burn it. Alot of it will go out your guides and not burn where as more of the conventional oil would burn. The amount of oil going out the guides would be the same if both oils were the same weight and new oil, but the conventional will smoke more and if the oil is old the conventional oil will thin out and then be consumed faster as well.
Old Feb 3, 2002 | 07:37 PM
camaro6spd's Avatar
Replaced Valve seals and there is still smoke, only three of the valve seals where cracked the rest were fine...no orings in there tho...We tried teh new vavle seals witht eh 50wt oil....smokes lots of it....I tried 15-50 Moble1...smoke, not as much but sill very noticable....we put in a bottle of the thickest No smoke we could find...I will find out in the morning if how bad it is....I am thinking about the smokless chain saw oil....Ym father could put that oil in at school, (auto tech teacher), run it over to the station, pass it, bring it back and put the 15-50 back in and drive home....
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
355sbcTPI
Aug 19, 2015 04:38 PM
