Trans AM 86 TPI EGR
Old Jan 11, 2022 | 03:36 PM
adelane's Avatar
Trans AM 86 TPI EGR
Hello,
I have a 86 trans am with EGR Valve and a temperature sensor on the EGR Valve.
There are many EGR Valves, I don't which one is the good one with the place for the temperature sensor on it ?
DO you have a part number for the temperature, I found this but not sure :
https://www.corvettemods.com/C4-Corv...or_p_8351.html
And do you have a part number for the control valve ?
Thanks for your help
Marc
Old Jan 11, 2022 | 08:29 PM
Vader's Avatar
Re: Trans AM 86 TPI EGR
That is possibly your best chance at finding an EGR temperature sensor. The EGR Diagnostic Switch is a GM 14087416, AC/Delco 212-337, or Standard Motor Products ETS-2.
The EGR valve itself is a negative backpressure type, It is a Standard Motor Products EGV393, still available some places.
The EGR vacuum solenoid is GM 1997169 (Sorenson 7799607), and is still listed as available.
Old Jan 11, 2022 | 10:19 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Originally Posted by adelane
Hello,
Marc
I used that exact style EGR temp sensor, all you need to do is cut the plug off the end and splice into the old wire and your all set. This is what finally cured my Code 32. You can save almost $20 if look on eBay or other Corvette places.
https://www.southerncarparts.com/cor...oaAiVsEALw_wcB
If you can’t find the EGR valve Vader mentioned I used AC Delco 214-5538 from Rockauto and had no issues. It has the temp sensor threaded bung and actually clears the plenum because it has the EGR port set up like OE unlike many aftermarket that have a plastic nipple on the top that can possibly interfere with plenum clearance. I didn’t like that it was made in China but it is what it is. Also my car is a 88’ L98.
Old Jan 12, 2022 | 09:39 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
The last year, I replaced EGR + Temp. sensor with:
EGR Valve Standard Motor Products EGV393 +
1986-89 Corvette New EGR Sensor Replacement Switch GM 14087415
This Corvette sensor has a shorter wire that original Trans Am sensor, but I ran the wire under fuel rail and connect it with the original connector with no issues.
It works for me, but today I've pending the legal smog test, but in the last test, the NOX was approved with the old EGR blocked by previous owner
Old Jan 12, 2022 | 11:04 AM
adelane's Avatar
Hello All,
I ordered the egr valve on rockauto.
I will order the temperature sensor too.
But no way to find The EGR vacuum solenoid is GM 1997169 (Sorenson 7799607) ? do you have a link.
THanks
Marc
Old Jan 12, 2022 | 11:14 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...-solenoid.html
Old Jan 12, 2022 | 11:15 AM
Engine: Lb9
Transmission: M20
You can use a later 90-92 egr and delete the malfunction code 32 as a option
Old Jun 23, 2024 | 07:53 PM
Gunmetal87's Avatar
Car: 1987 GTA
Engine: 5.7L
@Vader if you had the choice of the two EGR Temp sensor’s would you go with a “new” corvette style switch (GM 14087415) or the original “used” one that came on our cars (GM 14087416)? The only issue I have with the corvette part is having to splice wires to make it long enough. I currently see both on ebay for sale so I would like to get a good knowledgeable opinion on which would be better
Old Jun 30, 2024 | 08:27 AM
Vader's Avatar
If I had a choice between a new switch and a used one, I would probably lean toward a new one. I can understand an argument for either choice, with a new one being, well, NEW, but possibly of unknown quality and robustness, and an original possibly having a lot of accumulated operating hours. The opposite evidence for the original is that mine is almost 40 years old and functions just fine, so durability is really not a question.
Old Jul 8, 2024 | 11:21 PM
KR81's Avatar
Since this thread has popped up I'll ask, if the ceramic part of the temp switch is cracked, does it affect its function ?
Old Jul 9, 2024 | 07:21 AM
Vader's Avatar
If the ceramic insulator sleeve is cracked, that does not necessarily mean the switch is bad. The only way to test the switch is heating to somewhere around 600°F and monitoring the switch continuity. If the switch is mostly intact and functioning, the ceramic could be patched with a high-temperature epoxy filler.
TylerSteez
Feb 28, 2017 06:33 PM
KustomIroc
Oct 16, 2004 08:34 AM
85Rock
Aug 23, 2003 06:26 PM
Redi2RocZ
Apr 29, 2002 12:56 PM
