Hoses
Transmission: T-5, TH350, T-5
Re: Hoses
It is for the heater hose. Why don't you just use it as a heater hose? Are you deleting the heat?
Re: Hoses
Probably more work than it's worth to put it back in but it is nice to at least have defrost.
As far as your hoses, I'd suggest running a bypass hose from the intake to the radiator or waterpump. (if you have a port on the wp)
It might not be needed but helps bleed the air out of the coolant system too
Re: Hoses
Re: Hoses
I don't know about a bolt in it but there is a 5/8 inch port port on some waterpumps.
otherwise yes, the 3/4inch port on the radiator is the return for the heater hose circuit
