Should distributor be able to move without loosening the nut?
Old Jun 4, 2022 | 01:19 PM
Fonso0812's Avatar
Car: 89 IROC-Z
I can see the distributor cap and shaft move but the nut is locked(i checked) car has been running crappy and Im worried the distributor might not be set right where its supposed to TIA
Old Jun 4, 2022 | 02:14 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Should distributor be able to move without loosening the nut?
I think you've answered your own question. Re-set the timing, and snug the bolt down...
Old Jun 4, 2022 | 04:54 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
No, the distributor needs to stay in place, otherwise your base timing will be thrown off.
Old Jun 4, 2022 | 07:41 PM
It is somewhat normal that you can move the shaft & rotor around by hand, with the motor sitting still.
If the dist body moves, that's a sign the hold-down hardware is loose or improperly installed. (half on, half off the flange, for example) Verify correct installation, properly adjust timing, tighten properly.
What vehicle / year / engine / induction system of 82-92 Camaro/Firebird is this?
Old Jun 5, 2022 | 01:46 AM
BOOT77's Avatar
People often over tighten the hold down bolt/nut and bend the bracket. Some aftermarket ones are pretty flimsy n junk.
Old Jun 6, 2022 | 02:14 PM
Fonso0812's Avatar
Car: 89 IROC-Z
Thanks for all the help guys, bracket had to be adjusted.I removed the distributor and now I want to put it back in. I removed spark plug and checked im on compression stroke, set the harmonic balancer to 0 (tdc), pointed the rotor on the distributor and meshed to cyl 1(not seated all the way). now when I try to seat the distributor by turning the engine manually the rotor starts to move away clockwise towards cyl 4 then it finally seats. Can I just go ahead and put the cap back on with spark plug 1 where it should be at originally even thought my rotor is seated and pointing at cyl 4
88-IROC 350
Old Jun 6, 2022 | 02:27 PM
erik69&85's Avatar
That was the oil pump drive engaging... Personally, I would rotate it back around to check you are on number one at the right time... Check twice... Never hurts even though it may be ok if it stayed in synch...
I usually line up the oil pump drive before dropping the dist in place...
Old Jun 6, 2022 | 02:56 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I would not run it unless the distributor is in exactly the right spot. It's not seating because the oil pump drive is rotated in the wrong spot. I manufactured myself a very long flathead screwdriver to turn the pump drive where I needed it to be so the distributor seats where I want it. Note: if you're connecting multiple tools together to get the length you need, tape and test all connections so they can't be separated. Dropping anything down into the valley means hours more work.
Old Jun 6, 2022 | 03:19 PM
Fonso0812's Avatar
Car: 89 IROC-Z
@erik69&85 you mean like rotate it manually again and make sure the rotor is at the cyl 1 position when the timing mark is at 0?
Old Jun 6, 2022 | 03:24 PM
Fonso0812's Avatar
Car: 89 IROC-Z
@Komet Ive got a pretty long screw driver i can use to try to line up the oil pump gear in the manifold, ill try that and see what it gets me as well. ive just seen a lot of people turn the engine and it lands perfectly where it needs to be for it to seat lol
Old Jun 7, 2022 | 04:27 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
After the distributor drops down onto the oil pump shaft, you can rotate the crankshaft around back to TDC and turn the distributor housing to point the rotor at #1 plug wire. Snug the clamp bolt not too tight so that you can still move the distributor by hand. Start it up, adjust timing with a timing light and tighten the bolt. Even doing this, the initial start might require moving the distributor a little one way or the other while someone is cranking it over to get it to start. It just needs to be close enough to start, then set it correctly with the timing light.
86bird86
Sep 26, 2008 03:51 PM
Shyft
Nov 15, 2007 04:58 PM
91CamaroRS1122
Mar 31, 2004 12:13 AM
jrl9873
Jun 30, 2002 10:38 PM
