URGENT: how to place gas tank
Old Jul 16, 2022 | 07:34 PM
Benny04's Avatar
Car: 1989 TTA #437
Engine: Buick 3.8 turbocharged
Am in the dreaded process of putting my new gas tank in, and Im up to my limits with this job. I have absolutely no idea how these are expected to go in, the lack of room is astonishing!!! I dropped my axle completely, shocks, exhaust, springs ALL REMOVED!!! there seems to be no way of getting the filler neck in and simultaneously placing the tank up against the frame. There is seemingly no end to this nightmare of a job. If anyone has any tips that would be greatly appreciated.
Old Jul 16, 2022 | 08:08 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
Re: URGENT: how to place gas tank
I have dropped my gas tank several times in my 83 Z28. I had help and we twisted and turned the tank to slowly feed the filler neck up into position. Then we lifted the tank up and held it in place with one person and a small bottle jack. The key thing we did was to take it slowly and not force anything. We had to pull it back out and twist and turn until we got the right angle to get the filler neck up. I did take out the plastic shroud around the filler neck to give us some more wiggle room. But I never removed the axle, we worked around it. It is not fun nor easy but it can be done Another key aspect is to have the car jacked up as far as possible. I don;t have a lift, we used large jack stands and a borrowed air powered end lift/jack and got the car about 2 feet off the ground. This gave us enough room to drop the tank and put in the replacement. I have since pulled the tank back out because I decided to replace all the fuel lines with Stainless Steel lines since I found several rust holes in the old ones.
Old Jul 16, 2022 | 08:51 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Have somebody look through the filler door and guide the neck into place. Probably just missing the hole over and over and over again.
Some 60-year-old woman installed these by herself all day in the factory.
Old Jul 16, 2022 | 10:30 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
...with LOTS of practice, into an unassembled vehicle, with a pneumatic lift, and perhaps other assembly aids.
It was easier in the past.
And it's worse in the future.
Hopefully the 3rd gen is somewhere in between.
Old Jul 16, 2022 | 11:09 PM
Benny04's Avatar
Car: 1989 TTA #437
Update: cut open where the filler neck went and slammed it in, was the only option besides removing the entire differential which I don't have a proper jack to do. Anyway, looks like I got it done... Lol
Old Jul 16, 2022 | 11:11 PM
Benny04's Avatar
Car: 1989 TTA #437
Won't see anybody else doing anything this stupid with their TTA's🥲
Old Jul 16, 2022 | 11:39 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Believe me, we all have secrets we keep of the work we did.
Old Jul 18, 2022 | 02:48 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah, lemme go get an air chisel so I can put my tank back in my TTA.
carcrazy1
Fabrication
Jan 4, 2011 05:01 PM
transamracer
Jul 15, 2005 06:25 AM
ken3983
Apr 13, 2005 09:18 AM
88IROC350TPI
Oct 21, 2003 08:22 PM
Eightyninef
Jan 8, 2002 08:43 PM
