Aftermarket heads
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Aftermarket heads
91 Z28 350 TPI
If I put aftermarket heads, intake manifold & carburetor on...
1. I will need a different distributor right?
2. Will the radiator fan come on when I turn the a/c on?
3. Will the radiator fan come on when the coolant sensor by the thermostat calls for it?
4. Will the radiator fan come on when the coolant fan switch in the right head calls for it?
The reason I would get rid of the TPI is don't' know enough about it, I can't tune it. I can tune a carb.
Re: Aftermarket heads
No one knows? I really would appreciate someone letting me know. Thanks.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
1. Yes
2. if you dont mess up the sensors or computer
3. / 4. all depends on what your fan setup is
5. Will my car always run like *** and get worse MPG than an EFI setup? Yes
91 Z28 350 TPI
Why not look into the self-tuning fuel injection systems like Holley and FiTech?
How To Install A Big Block Chevy Engine Into A Third-Gen! - Third Generation F-Body Message Boards
