cranking and fuel r ok but no start
Old Sep 14, 2022 | 08:33 PM
samurider's Avatar
Hi. I’m Japanese and finally got a dream car Transam!
A few weeks ago, it suddenly stopped during I was driving.
I made sure that fuel comes and spark plugs are ok but fuel doesn’t go to chamber I think.
Plugs are dry. Also some vacuum lines are dead and disconnect.
I don’t know how to connect them correctly.
Please help me!! thanks!
VIN:1G2FS23EXMLxxxxxx Year:1991 Engine:5.0L
Last edited by Vader; Sep 15, 2022 at 07:47 AM. Reason: Full VIN not included for security
Old Sep 17, 2022 | 10:40 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: cranking and fuel r ok but no start
welcome from this side of the pacific You could check for trouble codes stored in the ECM memory.Also tell if you have theTBI(large round air filter) or TPI engine.
Old Sep 17, 2022 | 11:50 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
VIN is E code so I'm guessing TBI. Original Poster, is this what yours looks like?
As far a vacuum lines, that diagram should be correct. Fix those first.
Is fuel being sprayed from the injectors? That you can visually see without doing anything but crank the engine over.
Old Sep 17, 2022 | 12:27 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
reply 3,looks like you have the hose diagram for a Fiero or Citation there
Old Sep 17, 2022 | 02:33 PM
Ha, so I did. Corrected. I must Have been distracted by the purty colors when I picked the diagram.
79monte
Aug 12, 2014 07:40 PM
KingsHustleLA
Oct 16, 2013 07:38 AM
xrageandfearx
Aug 3, 2012 02:25 PM
BladeX10
Aug 22, 2008 03:18 PM
MavViper
Jul 24, 2007 06:36 PM
