So i just pulled 4 of my spark plugs..
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: So i just pulled 4 of my spark plugs..
lol....... too much fuel duh..... fuel smell?
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Your car is running way too rich. That's why you have the excessive carbon deposit. Is your engine carburated or fuel injected? Don't know much about car carbs, but in the case of motorcycles this is usually caused by the carbs being jetted too large.
If the car is FI, you could have a bad 02 sensor, leaking fuel injectors, or too much fuel pressure.
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
if his car is stock it's got a computer controled Q-jet, chang out the plugs and the O2 sensor, and if that dosen't work you might need a re-build on the carb, I honestly could never get them to work right and i went to a edelbrock Q-jet and a vaccume distributor (when it was a 305) there allot easier to work W/
Engine: 383
if it's got a holly on it than it's not stock.... O2 sensor is moot...it sounds like u need to re-jet it down a few jets
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You guys are joking right?
Am I seriously the first one to ask
WHICH 4 SPARK PLUGS DID YOU PULL?!?!?
Did you pull all 8? Are they all the same?
Holley carb eh? What intake manifold is on it?
Go pick up a manual on holleys, and a jet kit. You'll need to lean it out.
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
run a can or two of seafoam through gas tank and it will clean out carbon (just one can at a time)
Dont know the intake manifold.. Ill let you know once i get all the build up garbage off it
Just found a manual for the carb a few mins ago.. Reading it now
Car: 1982 Trans-Am
Check the other side first.
Got 2 off the other side.. They are just as dirty and smelly as the driver side.. The first thing i should have gone was replace these plugs. lol.
Car: 1982 Trans-Am
Ok, fair enough.
I'd tune the carb first, otherwise you're probably gonna ruin more plugs. Clean these with a wire brush.
Try to tune it based on vacuum and speed and sluggishness/surging. That'll be ballpark. Then throw in new plugs with silver threads, rather than black. Then continue, read plugs, etc.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Mechanical/vacuum distributor to go with that carb or the original computer controlled dist in there? Make sure you're good on ignition and timing before thinking about doing any changes to the carb.
Retarded timing and improper advance can exacerbate a rich condition.
I dont think the plugs have been replaced since 2004-2005.. Unless there isn't a reciept for a newer set of plugs.. Maybe the plugs just got old?
