Can You ID This Ignition Part?
Old Oct 26, 2022 | 11:17 AM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Transmission: 2002 T-56 6-speed
Axle/Gears: 4.11
This gizmo sits above the coil, has a white wire in and a white wire out that goes to the coil. No other wires.
Old Oct 26, 2022 | 11:18 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Can You ID This Ignition Part?
Unplug see if tachometer stops working
Old Oct 26, 2022 | 11:49 AM
It's called a "connector". It allows 2 wires to plug into each other.
Looks kinda like one of the wires has seen better days.
Old Oct 26, 2022 | 03:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It's a connector. I think I've read someplace the service manual calls that location a tach filter. Although I've had these apart and haven't seen anything other than a connector.
Old Oct 26, 2022 | 04:15 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Sure looks like it has something to do with high speed fan, those connectors often get melted. They were on my car and when I researched it that’s what I found.
Old Oct 26, 2022 | 06:16 PM
OrangeBird's Avatar
Car: 1989 Firebird
It's a somewhat similar looking connector, but the small gauge white wire is the giveaway that it's in the tachometer circuit. The high speed blower relay has a much larger gauge red wire(connector C105 in this way too dark diagram)....
Old Oct 26, 2022 | 06:36 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
Thanks Sofa, I appreciate the humor. Maybe I worded my question a little loosely.
Yes, a connector. Since it's in the coil circuit and only has one wire in and out I figured it must be more than just a connector. My first thought was an RFI filter, which were common on older can coils and attached to the (-) terminal of the coil.
It is a little rough on one end and I would like to replace it. Easier to find the part if I know what to call it.
Old Oct 26, 2022 | 09:47 PM
No really, just a connector.
You are right, there IS a noise filter in at least some of these cars; looks alot like an old ignition condenser from the Cro-Magnon days of points setups, except it has a wire coming out of each end. It's not impossible that such a thing would have had those same connectors on its leads. My 83 has one of those, not sure what cars/years did or didn't get it, or why.
Old Oct 27, 2022 | 02:27 PM
vorteciroc's Avatar
Top Answer: 1
It is just the Connector for the Tachometer Signal.
bjm1206
May 11, 2011 12:22 AM
firebirdjosh
Feb 21, 2007 01:44 PM
87tpi420
Jul 17, 2001 11:51 PM
Corry
Sep 22, 2000 07:42 PM
Corry
Sep 22, 2000 12:14 AM
