Afpr
Old Nov 29, 2022 | 12:24 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Afpr
Can someone tell me the general location on their afpr set screw at correct pressure. (Southbay , screw on top)
I am currently unable to check fuel pressure. Want a good starting point. I assume right turns of screw increases pressure. Correct?
Old Nov 29, 2022 | 12:28 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Afpr
A good starting point is get a gauge and check. What engine modifications have been done or what injectors being used that need higher pressure?
Old Nov 29, 2022 | 12:42 PM
Engine: 5.7 l98
Re: Afpr
I agree, problem is I broke off scrader port so I have it sealed with screw at the moment. Ported tpi top end, 26pd injectors
Old Nov 29, 2022 | 12:56 PM
Engine: Lb9
Transmission: M20
Re: Afpr
if only modifications is ported 22#hr and tuning is the best solution. Running 26#hr with an injector constant of 22#hr you will be rich. Add more fuel pressure to that doesn’t help the situation.
Old Nov 29, 2022 | 12:57 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Afpr
You could tee a fuel pressure gauge into the feed line on the driver's side of the engine, I suppose. But, there's no way of telling how much the screw needs to be in or out without a gauge.
Old Nov 29, 2022 | 02:13 PM
Engine: 5.7 l98
Re: Afpr
It is tuned for those injectors
Old Nov 29, 2022 | 02:16 PM
Engine: 5.7 l98
Re: Afpr
Yeah it looks like I'm gonna have to buy a fuel rail just to get another shrader valve port. Can't find one to match those threads. I was just looking for what was average on everybody else's to get it around correct pressure.
Old Nov 29, 2022 | 02:20 PM
Engine: Lb9
Transmission: M20
Re: Afpr
if it’s tuned, than once again no need for the bandage afpr.
Old Nov 29, 2022 | 02:25 PM
Engine: 5.7 l98
Re: Afpr
I'm not sure what you mean by bandage afpr. I'm just trying to get the fuel pressure in a good range whether that be most people screwing it in 5 turns or all the way out! When I fix the port I will be able to tell I'm just looking for advice on trying to get it within range At the current moment.
Old Nov 29, 2022 | 02:30 PM
Engine: Lb9
Transmission: M20
Re: Afpr
If it’s tuned it’s tuned at 3 bar , increasing it won’t help if it’s tuned properly with datalogging, correct flow rate in constant and correct voltage offsets. Leave it backed off all the way. You complicating things if it was tuned.
Old Nov 29, 2022 | 02:44 PM
Engine: 5.7 l98
Re: Afpr
OK that's exactly what I needed to know . with the screw backed all the way out it should be stock fp?
Old Nov 29, 2022 | 02:53 PM
Engine: 5.7 l98
Re: Afpr
Thank you , btw u Wouldn't happen to know where I could get The schrader valve port would ya?
Old Nov 29, 2022 | 03:02 PM
Engine: Lb9
Transmission: M20
Re: Afpr
There discontinued years ago, would need a used rail
Engine: 5.7 l98
Re: Afpr
Thanks again for your help
Old Nov 30, 2022 | 05:07 PM
southbay08's Avatar
Re: Afpr
Hey give us a call....
516-442-4707
Old Nov 30, 2022 | 10:08 PM
Engine: 5.7 l98
Re: Afpr
516-442-4707
I need housing of the valve. Not the valve itself . I have actually called you about it a few weeks ago.
perZ
Jun 15, 2016 09:17 PM
racerx520
Jul 30, 2014 04:55 PM
87hellbird
Jun 29, 2011 05:13 AM
twadam
Aug 11, 2006 01:35 PM
andrew350
Aug 21, 2001 01:44 AM
