350 cooling port blockoff?
I'm in the process of turning the TBI 350 engine in my car back from a lousy carb conversion by a previous owner to TBI, and the intake manifold gasket set I got for the original GM TBI intake manifold I'm using has the two end ports blocked of with metal rectangles with very small holes drilled in them. I've read this is to block off the two rear ports. I'm wondering why you would want to block off these ports because they aren't blocked off in the heads or intake. Should I leave the little block-off plates in or take them out?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 350 cooling port blockoff?
