89 Camaro has troubles staying started
Hi. Since I got this car, I have had one frequent problem that I do not know where to begin with when diagnosing. I can start and drive the car no problems, I can leave it in idle and it will not shut off. However, if I drive the car, and then let it sit for maybe 15 or more minutes, when I start the car, it will die almost immediately. I have to continually pump the gas for a good minute until she decides she can idle on her own without dying. If I tried to hold down the gas it seemingly won't take it all. It will take a blip of gas, and then stop even if I keep my foot on the gas (Is this to prevent flooding?). So, I continually pump the gas giving it blips at a time until it is back to normal. Whenever the car sits for extended periods like more than 4 to 5 hours the problem subsides, and the car starts normally again. If the car does not sit for more than roughly 15 minutes in-between being driven, then it will start up no problem.
Any info on where to start looking is very much appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 Camaro has troubles staying started
Definitely sounds fuel related, have you ohmed the injectors cold and hot ?
are they the original multec grey body injectors ?
I appreciate the info greatly.
Engine: Lb9
Transmission: M20
https://www.harborfreight.com/11-fun...ity-61593.html
might even be a cheaper option, you can do engine off ohm them start the car even a short drive to hear everything up then check ohm reading again. May want to write down and post results.
Since this happens warm... May be a temp sensor issue. The car thinks it's cold when it's not so the computer is sending the wrong info... I would check the output of the coolant temp sensor that the computer uses.
If it runs fine all the rest of the time, I am less inclined to thinks it's the injectors and more in the feedback sensors...
But I also had an 89 that was hard to start cold... But that was a computer replacement... Learned to make sure the key was out of the ignition before reconnecting the battery! Damaged the ECM...
After reviewing the information above, I'm not completely confident that the vehicle has injectors for which resistance measurements can be taken. Nothing was ever mentioned about TPI.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
If I may add, I was wondering the same. No mention of type of engine. TPI, TBI TPI350, V6?. Original? Transmission?
Engine: LT1 6.2L
Axle/Gears: 3.91
Usually, checking the basic system like fuel & spark, helps eliminating possible causes.
After that, without a datalogger, it can be tricky to figure out what's going on with EFI
