Replaced Fuel Pump in 89 GTA (the easy way)
Old Mar 21, 2023 | 08:38 AM
89GTASC's Avatar
Car: 89 TransAm GTA
Engine: 5.7 TPI
Transmission: AUTO
Axle/Gears: 3:27
My fuel pump died, luckily it let me get it back home. Anyways we searched on youtube for how to replace the fuel pump, and did you know if you do it by the book, its like 4.5 hours profession mechanic labor and you have to remove your exhuast, and I think the rear axle, to be able to drop the fuel tank to access it. Then we found some vids on youtube on how to replace it the "easy" way and that was to cut a whole in the trunk area, which in our opinion was the way to go. And it makes for a much easier fuel pump replacement if we ever need to do it again. I'll try to share the youtube vid links and maybe some pics.
Old Mar 21, 2023 | 08:46 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Replaced Fuel Pump in 89 GTA (the easy way)
Oh no.....I'm speechless.
Old Mar 21, 2023 | 09:43 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
I would never cut a hole in the trunk. Just my opinion.
Old Mar 21, 2023 | 10:02 AM
89GTASC's Avatar
Car: 89 TransAm GTA
Engine: 5.7 TPI
Transmission: AUTO
Axle/Gears: 3:27
I understand that. But I am ok with it. I definitely don't foresee myself ever selling my car or anything. Especially those cars where you want to keep it as original as possible. But this car isn't that. It's just my fun toy that I ended up keeping just cuz I didn't find anything better to replace it with disappointingly. Sure faster maybe, not better imo. I got the car in 2001-ish w 145k miles for $2500. Transmission rebuilt at 175k miles(10+yrs ago), car now has probably 250k miles. Just hanging in there. I myself wouldnt have done it, but my dad, I have seen him replace parts in the back of the engine(something for the heater) and cut a whole through the firewall to get to it[different car 90 Ford Taurus]. I was shocked as well. But when it came to this one, I have a custom exhuast and I really didn't want to try to disassemble it. So my Dad and I were on the same page for this one. Another note when buying a replacement fuel pump.. was reading reviews where they had 1-2 bad fuel pumps until they got the 3rd one which worked fine... Aint no way we was gonna do all that over again. Again... maybe if the car was something special w low miles or whatever, but nayy it's just something I enjoy driving.
Old Mar 21, 2023 | 12:43 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
I'm a purist, and would never do that. Butchery, IMO......but to each, his own. Your car.
You should at least clean up and pretty up the hack job by installing one of these:
https://allstarperformance.com/searc...access%20panel
Old Mar 21, 2023 | 01:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Well, it's your car. Honestly, It's not hard to lower the tank and takes about the same time. Plus it gives you a chance to look things over in the backend.
Old Mar 21, 2023 | 02:06 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
The bigger problem with what you've done there involves those pieces of hose and those sketchy worm clamps. I would hope that you at least put flares on the ends of all the metal lines. There's fuel under pressure there; a leak might not be readily discovered in such a hidden place and could be catastrophic.
As far as hacking a hole in the car's floor...well, it's your car.
Old Mar 21, 2023 | 04:07 PM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
I believe you're talking about putting a "bead" near the end of the tubing, not a "flare." With a bead, the hose would slide smoothly over the bead, and then the hose clamp would install on the back side of the bead.
Old Mar 22, 2023 | 07:08 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
You pretty much butchered that car.
Old Mar 22, 2023 | 05:45 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Here we go again.......
Old Mar 23, 2023 | 05:40 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
If you own a car, be a mechanic!!!
It's not that hard to do it the correct way and you can even upgrade items along the way. STOP ruining cars that are hard to find in the first place!!!!!
Old Mar 24, 2023 | 10:49 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Hole is cut on my car. No one will know the difference. Makes it much easier for repair/upgrades in the future. Quick diagnosis as well. Fuel pump is now a fifteen minute ordeal with basic hand tools. Just make a nice hatch/cover!
Old Mar 25, 2023 | 12:23 AM
Engine: 5.7 l98
A hole is no help in diagnostic or upgrades. The correct job also is done with basic hand tools. If you do a job and say to yourself "no one will know" you have done the job wrong!!!!!!!
Old Mar 26, 2023 | 09:47 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Old Mar 26, 2023 | 10:42 AM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
This is better....
Old Mar 26, 2023 | 11:35 AM
Engine: 5.7 l98
Old Mar 26, 2023 | 11:52 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
@89GTASC
This topic has been beaten to death here and probably all over the internet. I'd say over the last 2 decades, if not longer. Do some simple TGO thread searches, Google and YouTube and you'll find tons of info, Pros and Cons, bla bla bla.
No need for yet another thread where all you are going to get is another annoying emotional debate instead of the "How to do it".
This guy did a great job:
Peace.
Old Mar 30, 2023 | 05:59 PM
erik69&85's Avatar
Did the OP thinks this was a new, special idea?...
This was being debated when I joined this site.... In 2001...
Btw, I had to replace my fuel pump in 2012... Did it the right way... Dropped the tank, cleaned the tank... Have not touched it since... That's a shortcut you might never need again...thank God all three of my tpi cars have not had holes cut in them... The idea of cutting fuel lines.... Gives me the Herbie jeebies...
cam406406
Nov 13, 2017 05:10 PM
johnw999
Jun 2, 2017 04:57 PM
1o80b
May 4, 2011 11:23 PM
98camaross
Oct 23, 2000 09:24 PM
