In search of 86 Shop/Service Manual
Old Apr 4, 2023 | 11:45 AM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
I'm looking for a pdf version of the 86 or earlier shop/service manual. I need to see some troubleshooting flow charts for the map sensor circuit on a LG4. Willing to purchase.
Thanks,
Old Apr 4, 2023 | 01:16 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: In search of 86 Shop/Service Manual
I have paper copy of 1987 manual. Probably the same. I'll see if can take pictures of the pages and PM if no one else pipes up.
Old Apr 4, 2023 | 01:45 PM
Car: 86 Berlinetta
That would help me out for sure! I'm attempting to build an adjustable regulator for the input voltage on the map sensor but the Haynes/Chilton manuals don't have any useable info.
Old Apr 4, 2023 | 05:59 PM
Vader's Avatar
The 5V reference source for the MAP is shared with the TPS and Baro sensor in the factory wire harness. It originates at pin 21 on the ECM.
It would be possible to split the wire harness and slave in a separate source to the MAP, but for what purpose?
Old Apr 4, 2023 | 07:42 PM
Car: 86 Berlinetta
I'm running the CCC system with a tight LSA cam. Everything works decently but I need more fine tuning. Basically, at idle in gear the lack of vacuum is causing issues for the computer. If I can adjust the voltage input on the map sensor I can theoretically move the value it's providing the computer to a range that's "acceptable".
I'm planning on installing a 12v regulator, but I need to better understand how the computer is reading the sensor and what range it considers acceptable at idle. Details here: http://gojeep.willyshotrod.com/HowtoMAPsensor.htm
Old Apr 11, 2023 | 03:02 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I have a 1989 and a 1991 Camaro service manuals, would that help? If so PM me.
Old Apr 11, 2023 | 09:16 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I have a 1986 shop manual. Are these the pages you are looking for?
Old Apr 13, 2023 | 09:26 AM
Car: 86 Berlinetta
Thanks, all. Aaron sent over some scans that I was able to use. I got all of the parts for the regulator so I'm hoping to have some results shortly.
spkx714
Aug 30, 2010 08:44 PM
loud91rs
Nov 11, 2008 12:45 PM
orangemonster
Jul 18, 2008 04:21 PM
Oddball
Dec 28, 2003 03:13 PM
jfreeman74
Apr 20, 2002 03:34 PM
