does running around with the ac compressor on all the time affect milage?
Old Jan 21, 2002 | 03:27 PM
matthew's Avatar
hey guys, I have never been satisfied with the milage my car gets. I usually get aroun 18-20 mpg. Most of my driving is highway, so I think it could be better. My car has just a stock LG4, I replace the cat with a high-flow unit, and got a new cat-back, but still no gain. My cap, rotor, coil and wires are new. But when I drive, I always have the defroster on because my windows fog up so easily and my fan doesn't work. Could the fact that the compressor is always on hurt my milage? Any other suggestions on what to do.
Old Jan 21, 2002 | 03:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If the compressor is on where the belt is being used, then yes your milage will be affected and also your power.
Old Jan 21, 2002 | 10:04 PM
matthew's Avatar
do you think it affects it enough to drop it down 2-3 mpg?
Old Jan 22, 2002 | 02:26 AM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
What good is the defroster if the fan doesn't work? And yes it could cut your mileage 2-3mpg.
Old Jan 22, 2002 | 02:30 AM
Car: 99 Formula
Axle/Gears: 342
I missed that part. Yeah, if your fan doesn't work then your defroster shouldn't either. Or are you talking about the fan for the AC. I didn't think the AC turned on when the defroster is on, of course my AC has been out of the car so I don't know.
Old Jan 22, 2002 | 07:52 AM
82camaro's Avatar
Car: 82 camaro SC
Without the fan working, he will get some 'flow through ventilation" to defrost the windshield. Yes the AC compressor runs while the defrost is on. Yes it will hurt mileage. The amount is determined by a lot of factors--such as cruise rpm, how full of freon, etc...
Old Jan 22, 2002 | 07:03 PM
matthew's Avatar
yea what 82camaro said, I still get some air through, but it only works a high speeds, which sucks. I should get that fan fix some time, lol. I can't wait for the summer when I don't have to run with my defroster on anymore. Do any of you guys know if the anti-fog stuff works? I tried it once and it seemed like it made things worse.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
justin57
Aug 20, 2015 07:05 PM
Street Lethal
Aug 13, 2015 08:28 PM
