Full battery barely any crank
Old May 29, 2023 | 07:45 PM
murphymckenna's Avatar
Car: 1986 Camaro Z28 Iroc-z
Hey thirdgen, so I tried to fire her up today (hasn't started in 10+ years) she seems to want to start but I can't get the car to turn over long enough before I hear the solenoid and it stops turning ! So am I nor getting enough power to the starter? I replaced the starter a week ago and just had the battery tested it Says it all good, what should I look for? i have 12-13 volts going to the solenoid, I'm pulling my hair out because I feel I'm so close to starting this beast !
Old May 29, 2023 | 07:50 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Full battery barely any crank
Battery cables...
Old May 29, 2023 | 08:06 PM
**** could it be that simple ? I'll update you guys tomorrow with my findings
Old Jun 4, 2023 | 06:01 PM
You guys were right ! Now I have full crank but it seems as though the timings off, it won't start but fires a couple cylinders. Any tips with the timing ?
Old Jun 4, 2023 | 11:07 PM
T.L.'s Avatar
Check to make sure the firing order is correct. If it is, rotate the ditributor slightly each direction until the engine starts...
Cole
Jun 1, 2016 05:14 PM
kowboy59
Aug 28, 2007 11:41 PM
jethawk
Mar 7, 2007 11:55 AM
*F-BodyFanatic*
May 9, 2006 09:13 PM
super83Z
Jul 18, 2002 09:48 AM
