Oil dipstick after header install?
Old Jun 14, 2023 | 07:11 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
What are my options for a oil dip stick after my shorty header install? I have no airtubes. All I see is the lokar 99238FP? Is everyone really spending $105 for a dipstick and tube?
Old Jun 14, 2023 | 07:16 AM
Re: Oil dipstick after header install?
Use the original hardware (stud kind of thing) with a tube of some sort such as water pipe to replicate the thickness of the manifold.
Old Jun 15, 2023 | 10:39 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I used one of those stainless braided flex tubes from Summit. Works pretty good.
Old Jun 15, 2023 | 02:13 PM
Engine: 5.7 L98
Axle/Gears: 3.77
I ended up buying a Mr. Gasket 9705G Polished Aluminum/Braided Dipstick for 1980-Up SBC for $45 so we will see if this works or not.
Old Dec 19, 2023 | 04:59 PM
hassgrant's Avatar
Car: '91 Z28 305 TPI
Transmission: Manual
I just installed some of Doug's shorty headers and when trying to remove the nut that holds the oil dip stick, it torqued and destroyed my dipstick. Now, it is impossible to find a replacement based on GM 10055724. Does anyone know of any other options? I ordered one from Specter (chrome) but the tube diameter was too large to install.
Any help would be greatly appreciated.
I included pictures of install for viewing pleasure.
Old Dec 19, 2023 | 05:06 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I have the Lokar dipstick with my headers, but it is pretty much useless if the car is hot. Wish the handle was longer. As it sits now, it is right by the header tube.
BTW, hassgrant, that is a very nice looking engine bay.
Old Dec 19, 2023 | 05:20 PM
hassgrant's Avatar
Thank you for the compliment and the recommendation!
Right now I just took my broken tube and pinched it off so I can keep oil from blowing out until I get a new tube.
My idea was to get the car painted this week, but the header job caused me some issues: 1) broken oil tube; 2) waiting on new O2 sensor; 3) broke the coolant fan switch on passenger side.
Now I have to wait on parts so I can start the car and take to the paint shop.
It's always something!
Old Dec 19, 2023 | 08:55 PM
skinny z's Avatar
Just finished with the install of a fresh engine.
I went with an inner tube from Shafer.
https://www.summitracing.com/parts/ssh-idt001
The dip stick and external tube was some Amazon special.
Amazon Amazon
Both fit well. No additional support of the outer tube was needed. Just be sure you orientate it the correct way because twisting it into the proper position isn't as easy as you might think.
Old Dec 19, 2023 | 09:23 PM
Originally Posted by hassgrant
3) broke the coolant fan switch on passenger side....It's always something!
Lol. I did the exact same thing working on my exhaust last week. First broke the switch connector just trying to get it off. Barely touched it and it broke right in my fingers. Then broke the switch itself getting the manifold out. Those things are fragile.
89mulletbird
Aftermarket Product Review
21
Aug 24, 2015 06:01 PM
Excellegions
Jul 14, 2011 09:33 AM
dtorres
Apr 2, 2010 02:52 AM
85qjet
Sep 17, 2003 05:52 PM
primer84z
Mar 31, 2002 11:24 PM
