350 carb setup
Old Aug 7, 2023 | 04:29 PM
ThirdGenCD90's Avatar
350 carb setup
I recently picked up an 89 rs with a bad engine it had tbi 350 ive swapped the engine to older 350 with carb this is my first time doing anything like this i would like to know if the in tank electric fuel pump is safe to use with a regulator to the mechanical pump that will be feeding fuel to the carb? If not please tell me a good setup if possible thanks to any help im advance
Old Aug 7, 2023 | 04:51 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: 350 carb setup
If you have a mechanical pump why not use that and simply disable the electric pump the fuel will flow right through the electric pump being pulled by the mechanical pump the other option would be to skip the mechanical pump and use a regulator to drop the electric pumps pressure down to 5-7psi that should work pretty good ive done that on a few projects and it worked great good luck
Old Aug 7, 2023 | 04:56 PM
Re: 350 carb setup
Why not just put the TBI on the "new" motor and send it?
Old Aug 8, 2023 | 09:51 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 350 carb setup
My recommendation: Put a regulator on and be done with it.
If you use a mechanical pump with no "pusher" pump feeding it you're most likely going to run into vapor lock issues.
Old Aug 8, 2023 | 01:13 PM
Re: 350 carb setup
Why leave the carb on it and fight that whole conversion hassle? Why do ANY extra unnecessary work? Not saying that's necessarily the case; butt if you don't HAVE TO use the carb, but could just bolt on the existing TBI instead, why not?
Old Aug 8, 2023 | 02:28 PM
Car: 1983 Z28
Re: 350 carb setup
Because the OP might not see it as a hassle.
Old Aug 8, 2023 | 02:44 PM
Re: 350 carb setup
I'm asking the OP, not you.
Let him make that call.
If he doesn't know what it takes to make that swap, it just might be.
Old Aug 8, 2023 | 07:45 PM
Engine: LT1, L400
Re: 350 carb setup
I wonder what the OP's plan for ignition timing is?
Soupyman
Carburetors
Feb 13, 2022 04:07 PM
PFC FNG
Carburetors
Jan 18, 2009 05:12 PM
85blackberlinet
Carburetors
Apr 6, 2006 01:59 PM
