Wont Run!
Old Aug 12, 2023 | 06:54 AM
newman041786's Avatar
Car: 91 Camaro z28
Engine: ZZ4 350 TPI
Wont Run!
I have a 91 Camaro Z28 350 swapped with TPI that won't start unless I put starter fluid in throttle body. It will crank but won't start. No headlights and electric windows won't go down. I don't hear the fuel pump prime. I've put in a new fuel pump. I've put in a new vats bypass module in. I've changed the two relays on the fire wall. I've put in a new oil sending sensor I've changed every single fuse under the dash. New Ignition coil. still can't get the car running. can anyone help? Thank you
Old Aug 12, 2023 | 08:05 AM
Re: Wont Run!
Sounds like one of the fusible links down near the starter.
Old Aug 14, 2023 | 05:41 AM
Car: 91 Camaro z28
Engine: ZZ4 350 TPI
Re: Wont Run!
I was thinking the same thing, but I have the old SLP short tube headers and it looks like I'm almost going to have to drop the passenger side to access the starter and wanted to rule anything out before I do it.
CapsFan
Aug 12, 2016 10:30 AM
brockerboy
Mar 29, 2016 04:15 AM
Greg1309
Jan 19, 2013 07:52 PM
4g63
Jul 27, 2011 08:45 PM
jamesmidnight
Sep 5, 2005 12:53 PM
