Oil pump drive engagement check, distributor, LT1 Intake conversion
Old Aug 30, 2023 | 11:21 PM
Yakmastermax's Avatar
Car: 1989 Corvette, 1991 Corvette, 1985
Transmission: ZF6 and 4+3
I did an LT1 intake manifold conversion for my L98
Spun a bearing at the track, zero oil pressure. Not sure which happened first the zero oil pressure, or the spun bearing.
I originally thought the bearing went first due to knock since the datalog was showing knock counts and knock retard.
Someone who had a similar experience brought up the potential that the oil pump drive shaft wasn't wasn't being adequately engaged by the distributor.
I am building a new motor now, 383 stroker. How do I check the distributor to oil pump drive shaft engagement to ensure this tolerance is within spec to make sure the oil pump keeps working and the oil pressure stays up?
Thanks!
Old Aug 31, 2023 | 07:42 AM
Vader's Avatar
Re: Oil pump drive engagement check, distributor, LT1 Intake conversion
The pump drive shaft could be installed with the coupler to the pump shaft, held on center, and the depth from the distributor mounting flange can be measured with a caliper. Compare that to the position of the drive lug on the distributor gear from the shoulder of the base.
Old Oct 12, 2023 | 12:37 PM
Picture with the pan pulled
How does this engagement look?
Not enough or adequate?
Old Oct 12, 2023 | 03:43 PM
Looks fine to me.
Old Oct 12, 2023 | 05:18 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Is this a go left go right kind of track? You might want a trapdoor oil pan and/or accusump.
spicybbq
May 26, 2010 05:31 AM
305 black ghost
Mar 4, 2008 11:04 AM
Wishmaster's87IROC
Jan 16, 2007 07:31 PM
Kanerus
Sep 2, 2005 10:23 AM
Air_Adam
Sep 12, 2004 03:34 PM
