Running Rich
Old Jan 21, 2002 | 10:24 PM
94'_SS's Avatar
Running Rich
I’ve had a rich start up condition for some time now on my TBI 88 Firebird and have tried to replace just about everything under the hood that might contribute to the black smoke on start up such as new TB, injectors, CTS, IAC, MAP, TPS, wires, plugs, cap, and rotor just to name a few. The plugs indicate a normal combustion so the problem only exists on warm startup conditions. I am at a loss on what else I should try to solve this problem and am looking for any other suggestions. I have also tried to lower the FP to 9 psi but encounter bog on acceleration and the car still runs rich on startup. Does anyone else have this problem with EFI I thought that only carbs would behave this way? Anyways thanks for any suggestions you can provide.
Old Jan 21, 2002 | 11:16 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
O2 sensor maybe bad?
Old Jan 22, 2002 | 11:45 AM
94'_SS's Avatar
No not the O2, matter of fact when I replaced it I lost about 1 MPG. Hows that for trying to get better gas mileage? Could pressure be built up in the tank enough to cause this type of problem? This problem only happens at startup so only the systems to get the car running are at fault I belive. Thanks for the reply keep them coming.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
