How would you do this?
Old Sep 5, 2023 | 12:38 PM
OddJack's Avatar
Have a 89 305 TBI 5 speed,, blown engine. Looking for 300+ hp and torque
Want to keep the car long term.
Have $7000 to spend.
How would you do it?
Old Sep 5, 2023 | 02:00 PM
skippermatt's Avatar
Re: How would you do this?
Are you going to rebuild the 305 and want 300+ out of that or are you willing to buy a used 350 block and build that. One of my cars use to have a 400hp 305 but it needed good heads and a pretty “big” camshaft and I revved it to 7500rpm, this was a stock bottom end, I got lucky and it never blew up, but who knows how long it would last. I now have a 350 in that car and it makes about the same power but is a much “milder” build and I feel durability is much better because I don’t need to rev that engine over 6500 to make the same power. A 305 could easily make 330hp with heads and a nice flat tappet cam.
Old Sep 5, 2023 | 02:07 PM
OddJack's Avatar
From what I heard 305 could be built for that hp but torque will suffer. I prefer a 350
Old Sep 5, 2023 | 02:09 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Buy an L31-R, have screw in studs and a spring kit installed in the heads. ZZ4 camshaft or something similiar in the 220 durationn range..Headers and full 3in exhaust. . Swap to a Holley Sniper
Old Sep 5, 2023 | 02:13 PM
OddJack's Avatar
This?
https://www.gmperformancemotor.com/parts/19432780.html
Have good track record here? What hp and torque can I expect with that setup?
Old Sep 5, 2023 | 10:36 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Junkyard L31 or a roller L98, stroker kit, AFR Enforcers, 220-230ish @ 0.050 cam with .500+ lift, miniram, long tubes.
And then a T56 when you crack the T5 in half on a full throttle 1-2.
Old Sep 6, 2023 | 06:08 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
I don't know where you are located but I am pulling out my L98 to do a swap. Runs great. Can hear run if you act soon.
Old Sep 6, 2023 | 11:27 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Spend some of that 7K where you need it now, suspension.
OddJack
Sep 21, 2023 07:26 AM
rmmstnr
Jan 19, 2008 12:13 AM
SLoW 89 maro
Oct 17, 2003 12:52 PM
dana mickelson
Apr 9, 2002 03:59 PM
speedtendancy
Sep 6, 2001 11:47 PM
