What are these holes on my intake?
Old Sep 11, 2023 | 06:31 PM
dylan0503's Avatar
Car: 1987 Firebird Formula
Engine: 305 Carbureted
Can anyone tell me what these holes on the side of my intake are? It’s an Edelbrock Vortec performer rpm and the whole are 1/2 inch. I’m confused what I could possibly use these for. Also is the hole under the carb the only vacuum port? Because I have a brake booster to run to it and a pcv so am I just supposed to run them to a T kind of thing?
Old Sep 11, 2023 | 06:53 PM
ULTM8Z's Avatar
Re: What are these holes on my intake?
Most likely exhaust ports for an EGR system. It should line up with the center exhaust crossover ports in the cylinder heads.
Old Sep 11, 2023 | 08:46 PM
dylan0503's Avatar
thanks man, I’ll just plug them then
Old Sep 12, 2023 | 06:04 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
For water heating the plenum in cold climates.
Old Sep 13, 2023 | 04:31 PM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
there not for egr, it's for an old style thermo choke, the exauast heats up en element and the choke linkage opens the choke up, that's y its under the linkage, if it were egr it wouldn't be threaded, it would be part of a triangular flange w a hole going to the intake and 2 bolt holes
Old Sep 13, 2023 | 08:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not even close, the choke thermostats use a rectangular opening with a bolt hole on each end. Those holes are there to route coolant under and around the plenum since vortec heads do not have an exhaust crossover passageway to heat that area. I have owned and run that manifold and had the coolant plumbed up.
Old Sep 14, 2023 | 11:07 PM
lewandom's Avatar
Engine: 383
learned something new, I was sure they were for an old thermo choke
Clements408
Dec 30, 2022 07:58 PM
davecassin
Sep 23, 2017 01:26 PM
lowridetractor
May 20, 2010 09:31 PM
89RsPower!
Jun 29, 2007 02:44 AM
weberflorida
Carburetors
Apr 5, 2007 07:28 PM
