‘85 ugly distributor issue. Accel or DUI Distributor?
Old Oct 10, 2023 | 12:52 AM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Need advice please. My son loves this car. 85 Z28 305 , 5 speed, computer controlled carb, HEI distributor. Distributor bushing wore out and is unrebuildable, tried three new different distributors and wouldn’t run. Took to our mechanic who tried his best but couldn’t get to run well as well with stock dist’s. He switched over to a vaccum distributor, ran well for an hour then fell on its face. Question (1) - Is this causing more problems by not having an electronic distributor? SES light is on. We tried stock AC Delco, Cardone and different caps from Auto Zone but none of the original style distributors would run worth a crud. Question (2) - Is the DUI brand computer controlled distributor for $300 or the ACCEL 59130 for $110 the answer???? We’ve previously rebuilt the CC carb , replaced valve seals and springs, fresh plugs and wires. Trying our best to analyze and not just throw parts at it. Up for any all ideas. Thank you for your help
Old Oct 10, 2023 | 06:23 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: ‘85 ugly distributor issue. Please help a Dad out!
Check your wiring. Distributor should be a pullout/drop-in fix with no issues. You may have a wire disconnected or something else going on.
Old Oct 10, 2023 | 06:32 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Why not just rebuild your distributor?
I recall having to do it on my 91 Silverado with a 305.
Old Oct 10, 2023 | 07:48 AM
Engine: 350 / 305
Axle/Gears: Stock
Thanks, will look again.
Old Oct 10, 2023 | 07:49 AM
Engine: 350 / 305
Axle/Gears: Stock
Wish we could but original wasn’t rebuildable. Thanks
Old Oct 10, 2023 | 08:12 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
There really isn't much to the electronic controlled distributors. If the old one worked except for the worn bushing, you could move all of the electronic parts over from the old one to the new one and try that.
Old Oct 10, 2023 | 08:56 AM
Engine: 350 / 305
Axle/Gears: Stock
thanks we will try that again. The AC, Delco, Cardone, and Auto Zone parts simply didn’t fit. The distributor caps wouldn’t fit flush and we had failed coils. Having a hard time with poor quality parts.
GND-646
May 26, 2010 12:48 AM
84CraZ28
Apr 9, 2010 06:44 PM
PhantomFE3
Apr 13, 2006 06:18 PM
Z-Man 85
Carburetors
Feb 4, 2003 08:55 AM
triplediver
Feb 7, 2002 11:37 AM
