305 TPI: Can't remove oil pressure sensor? (Endlessly spinning)
Old Oct 28, 2023 | 08:19 PM
SkiingOnIce's Avatar
Hi all, (1986 Trans Am, 305 TPI)
The connector to my oil pressure switch (or sensor?) sheared off, so I was trying to remove the unit to replace it. However when I try to unscrew it via the socket on the top, it just spins forever. Is there a different way to remove this sensor?
Also, is this the oil pressure switch, or oil pressure sensor? My oil pressure gauge is pinned to max when the car is on, so I assume this is what runs the gauge on the dash, but I'm not sure. It's located behind/under the distributor.
Old Oct 28, 2023 | 08:22 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 305 TPI: Can't remove oil pressure sensor? (Endlessly spinning)
It is a sending unit (there is no "sensor")...
Old Oct 28, 2023 | 09:06 PM
Thanks! So this is what reads out to the gauge on the dash, right? Sorry, I'm very new to working on this car.
Old Oct 28, 2023 | 09:29 PM
Yes, that's for the gauge.
It has a hex below the big can part as well. Probably ½" or 9/16". Try a short open-end on it when you find out what size it is.
Verynormal
Jan 2, 2022 02:41 PM
xxx3man`
Mar 14, 2009 02:35 PM
tecnoman
Apr 19, 2006 02:49 PM
91Z28-350
Feb 11, 2004 03:21 PM
ajm_shorty
Sep 11, 2003 06:34 AM
