Chip hurtles
Old Feb 23, 2024 | 10:26 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Chip hurtles
Help guys I’ve been calling and emailing TPIS for a month to try and get a chip and nothing. This Johnny B can’t get it right and I found a Harris tuning guy and he wants $230 for a chip. I need help been trying to get my new engine to run 350 ZZ9 cam 9.7 comp HSR 24lb inj and I need a chip. I’ve got the original 305 axxb hooked to a moats board and I have two aujp chips. If I get 22lb injectors and hook up a aujp will it run? What about Harris tuning are they legit? What’s up with TPIS.
Old Feb 24, 2024 | 07:09 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Chip hurtles
I saw Tuned Performance responded to your other post. He is your guy if you need a chip tuned to your engine.
I never heard of the others you mentioned but you will need to data log the ECM. I don't think anyone will get it right by just taking a stab at it going by just a parts list. You may want to find a complete memcal for a 350 that would be tuned for the 22lbs inj. This should get you alot closer than the 305 you are using now.
No IMHO I don't think dropping back to 22 lbs inj. will help, your 305 is tuned for 19lbs.
You could also consider switching the whole ECM to the EBL flash system where you are able to see the data real time and make the proper adjustments yourself.
Old Feb 24, 2024 | 07:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Chip hurtles
https://www.thirdgen.org/forums/afte...eer-clear.html
https://www.thirdgen.org/forums/tech...size-22-a.html
might read the responses on this post again
iroc383tpi
Aug 18, 2007 03:54 AM
iroc_cragg
Aug 6, 2002 09:16 AM
boogada186
Jan 29, 2001 07:17 PM
