Stock l98 tpi cam upgrade zz4 or tpis
Old Feb 24, 2024 | 05:30 AM
Thirdgen4me2's Avatar
Car: 91 Z28 / 86 Iroc
Engine: L98 / TPI 305
Transmission: 700r4 / 700r4
Axle/Gears: 3.23 / 2.77?
What are the differences? What would be better for a daily driver/roadtrip car?
Im doing a budget refresh on a 91 stock 5.7 car.
Old Feb 24, 2024 | 05:56 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Stock l98 tpi cam upgrade zz4 or tpis
That TPIS cam from Hawks is the wrong one for your 1991 engine.
Old Feb 24, 2024 | 06:04 AM
what is different the timing setup for the earlier cars?
Old Feb 24, 2024 | 06:07 AM
Is the zz4 a good choice? What else would need to be done for the zz4 assuming i reuse the existing heads. I do plan to do heads and exhaust after the car is sorted out. I’m just looking to get it back on the road for this season.
Old Feb 24, 2024 | 07:33 AM
ULTM8Z's Avatar
What are your goals for the car?
Old Feb 24, 2024 | 07:43 AM
a little more performance without sacrificing drivability. A/c .. powertour…long roadtrips…1000-3000 mile road trips but a fun car around town. Possibly a tkx in the future over the stock 700r4.
car has 3.23
Old Feb 24, 2024 | 09:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a ZZ4 cam and think I'd rather go with that tpis super profile l98 cam.
We put it in a friends 91 350 tpi and its really nice.
the ad may show a LS cam but it's description is mostly right. Give tpis a call or shoot an email to get the correct cam. (Jim is super busy so give him a bit)
Old Feb 24, 2024 | 09:24 AM
ULTM8Z's Avatar
If you want it to sound stock and pass emissions I'd probably stick with the ZZ4 cam.
Old Feb 24, 2024 | 01:54 PM
Airwolfe's Avatar
"This is a billet cam with a flat nose for the 55-86 SBC, and a cast iron distributor gear and is ground on a 112deg. lobe separation."
https://www.hawksmotorsports.com/sbc...ller-camshaft/
The version of the Super L98 cam shown in your pic is for a 1955 to 1986 SBC. It is a flat nose retrofit roller cam meant to be used in older pre 86 blocks that don't have provisions for a factory roller cam.
The version of the Super L98 cam you need for you 1991 L98 is the step nose cam for factory roller cam block made from 1987+.
https://www.hawksmotorsports.com/sbc...ic-roller-cam/
"This is a billet cam with a step nose for a retainer on an 87-94 SBC or LT1, and a cast iron distributor gear and is ground on a 112deg. lobe separation."
Old Feb 24, 2024 | 06:50 PM
Emissions is not a concern but drivability is. I will see if i can find a video of a super l98 sound.
Anyone have thoughts on lifters the reviews for comp cams lifters is not great..are any reusable? Is it advisable if they have 150k miles?
Old Feb 24, 2024 | 07:39 PM
TTOP350's Avatar
As long as the lifters roll smooth, I'd use them. The new stuf is a crap shoot anymore
Feb 24, 2024 06:39 PM
Tatr
Nov 21, 2016 06:02 PM
miller7c
Mar 17, 2009 10:43 AM
Johnny Blaze
Jun 26, 2005 06:35 PM
84L69TA
South West Region
May 17, 2005 09:53 PM
