zz4 cam
Old Mar 15, 2009 | 04:27 PM
miller7c's Avatar
Car: 87 trans am/ 87 formula
Engine: lb9/ l98
Transmission: 700r4/700r4
zz4 cam
I bought a zz4 cam off e-bay and when i had it setting next to my stock l98 cam the l98 looked bigger. I measured both with my calipers and the l98 cam measured approx. 575 compared to the zz4 @ 470? The l98 cam is all machined while the zz4 is still rough casting between the lobes. Is it possable the l98 cam isnt the stock cam? THe l98 cam does have numbers just after the fuel pump escentric
Old Mar 15, 2009 | 06:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: zz4 cam
There's no way a stock cam has .575" lift.
Old Mar 15, 2009 | 08:13 PM
miller7c's Avatar
Engine: lb9/ l98
Re: zz4 cam
Yeah i know! Plus the way im measuring isnt the correct way. Does anyone have a picture of a stock l98 cam?
Old Mar 15, 2009 | 08:32 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 cam
I have a new ZZ4 cam. You want me to look at the ends?
Old Mar 15, 2009 | 08:41 PM
miller7c's Avatar
Engine: lb9/ l98
Re: zz4 cam
The zz4 cam i have has 7818 WF cast in at the dist end and 4001 EP at the fuel pump end
Old Mar 15, 2009 | 08:43 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 cam
I looked anyway. I got it new in 2003 from scoggin-dickey. It is fully machined between the lobes, there's a pink-ish paint stripe around it just forward of the dizzy gear, the lift is 0.474/0.510", and the back end has two markings. The larger reads 071-FM31, and the smaller reads 279 00L. It has a fuel pump lobe, and one small white paint stripe just behind that lobe.
Old Mar 15, 2009 | 08:45 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 cam
These numbers were stamped by a computerized engraving machine.
Old Mar 16, 2009 | 03:10 PM
Abubaca's Avatar
Re: zz4 cam
Measurements sound right for a zz4 cam.
I can't imagine having a .575 lift cam and thinking it was stock.
Old Mar 17, 2009 | 08:20 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: zz4 cam
The two cams you have may have different size base circles. Most aftermarket cams have a smaller base circle than the stock cam.
Old Mar 17, 2009 | 10:43 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: zz4 cam
Since you mentioned the one you got isn't machined between the lobes, I think it is not really a ZZ4 cam. Install it in a block, get a dial indicator and a degree wheel, and really check it out.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Strick1
Sep 4, 2015 07:11 AM
