Quickest car with stock L98 cam
Old Jun 21, 2005 | 09:20 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just wondering how quick has someone gone with a stock L98 cam equiped car.
Old Jun 21, 2005 | 01:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i am approaching 13.7's with stock L98 on street tires....
there is one guy with a superram setup with stock heads and L98 cam and has gone 13.2 at 104......very nice
Old Jun 21, 2005 | 01:43 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Just curious, why stick with the stock cam if you have done motor work? Or is this conversation based on stock lower ends with just bolt-ons?
Old Jun 21, 2005 | 02:12 PM
Car: 1971 Camaro
Engine: 427
Yep, stock bottom end, with bolt ons.
Old Jun 21, 2005 | 02:41 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Gotcha
Old Jun 21, 2005 | 03:24 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
sounds like me....lol
13.21@104.63
Old Jun 21, 2005 | 06:48 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
My car has the cam that came in it from the factory when I bought it new. The car is a 1989 Trans Am GTA 350 with of course the L98 engine.
I have turned a 12.73 and 105.85 at California Speedway in Fontana. I'm using 1.6RR with Trickflow Heads. Allen
Old Jun 22, 2005 | 11:35 AM
irocbracketrace's Avatar
Car: 1988 Camaro
Engine: 496 bb
Transmission: 400 with Brake
Axle/Gears: 9" with 4:30's
I have an 88 Iroc that runs a best time of 13.75 @ 98mph with the stock cam, stock heads, stock rearend gear(2.73) and some aftermarket bolt ons.
Old Jun 22, 2005 | 02:33 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
13.34@103 is best...in unnaturally good conditions...runs 13.5-13.8@100-102 mph any day of the week.
stock bottom end
Old Jun 22, 2005 | 03:12 PM
Car: 1971 Camaro
Engine: 427
Sounds like some good running cars for a stock cam!
Old Jun 22, 2005 | 03:21 PM
Car: 1989 GTA
Engine: 369 TPI
Confession time: Actually my car does have the cam that came with it. However Chet Herbert Cams did a little grinding on the lobes and turned it into a ZZ9 equivalent.
Old Jun 26, 2005 | 12:16 AM
walrus108's Avatar
Car: 1989 GTA White Hardtop
Axle/Gears: 9 bolt 3.27
1989, did the undersized lobes cause any geometry problems and does that pose any concerns?
Old Jun 26, 2005 | 11:17 AM
Car: 1989 GTA
Engine: 369 TPI
Talked it over with Chet Herbert and the consenus was I did not need special push rods. Dyno Don refreshed my motor last year and came to same conclusion. Have about 35000 miles on the valve train with no problems. Allen
Old Jun 26, 2005 | 06:35 PM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Stock heads, stock cam, ported plenum, slp runners, best time - 13.35 @103
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
anesthes
Aug 8, 2015 09:37 PM
