LT1 cam in LG4 block pushrod length
Old Mar 1, 2024 | 09:32 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
I know somebody on here has done this exact thing already. If I retro fit an LT1 roller cam using the 3.1 lifters, how long will the pushrods need to be? Online I find info of 7.3 AND 7.5, which is it?
Old Mar 2, 2024 | 12:11 AM
Re: LT1 cam in LG4 block pushrod length
Your adjustable push rod will tell you for sure. No need to depend on some yutz on the Interwebz like me.
Old Mar 2, 2024 | 10:31 AM
Well, I'm kind of in a time crunch. Pushing to make my MSE driveable by April 15.........and my block and heads JUST went to the machine shop! Just thought somebody probably already went through this.
Old Mar 2, 2024 | 11:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
why guess ? Just measure and order a set of push rods
Old Mar 2, 2024 | 11:12 AM
You'll be in a worse one if you put the wrong push rods in and destroy things.
Not with YOUR parts in YOUR motor. Which is all that matters. What fit somebody else's parts and motor won't necessarily fit yours.
Old Mar 2, 2024 | 12:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a pushrod that will give you a proper valve train geometry. The only way to know the proper length is with an adjustable pushrod. I think 7.3 and 7.5 can be measured with the same adjustable pushrod.
There's a difference between assembling an engine and building an engine. If you're building an engine, it would probably be stripped down at least 3 times do get proper machine work measurements.
Like mentioned above, it's your engine with your parts. Nobody can tell you what part to use because it's not OEM. Swapping parts usually means other that have also changed.
Old Mar 2, 2024 | 12:28 PM
Found some info through research this morning. ASSUMING stock block and heads.
Stock gen1 sbc pushrod length +/- 7.8" with oe style hydraulic flat tappet lifter seat height of +/- 2.0"
87-up with factory roller cam use a +/- 2.6" lifter seat height and a 7.2" pushrod.
MOST retrofit roller lifter are around +/- 2.5" seat height requiring a 7.3" pushrod
The 3.1/3.4 v6 oe roller lifters have a 2.26" seat height, requiring a +/- 7.5" pushrod.
Again this would be assuming STOCK heads and valve setup. Your results may vary.
I hope this helps anybody else trying to retrofit a rollercam into a gen1 block.
Old Mar 2, 2024 | 12:54 PM
Engine: Lb9
Transmission: M20
with all the assumptions, just check. It’s the right way
Old Mar 2, 2024 | 01:07 PM
Yes, I will once I start putting the engine back together. Would just like to have the right length on hand so as not to wait any longer than absolutely necessary.
If all else fails...........I'll TOW it to the show and enter in "under construction" class.
Old Mar 2, 2024 | 06:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Those numbers are still going to be ballpark.
Has the deck been milled for squareness?
Have the heads been milled for squareness?
Has the camshaft been changed? A higher lift cam does not increase the lobe height. To get more lift, the base circle is ground down. That means a longer pushrod is required to achieve proper valve train geometry. That's why you can't guess at the length and pushrod length needs to be measured. Too many variables to just guess at a length. An adjustable pushrod will be cheaper than buying a set at the wrong length.
XChris1632X
Oct 10, 2006 12:03 PM
Casey_Butt
Jun 19, 2004 06:08 AM
matt formula
May 12, 2004 12:06 AM
Air_Adam
Aug 17, 2003 11:36 PM
trans_am_ta_84
Jul 30, 2003 08:54 PM
