Electronic timing advance bad??
Car: 1982 Pontiac Firebird SE
Engine: 305 V8, LG4
Transmission: TH200c
'82 LG4 Firebird, replaced entire distributor assembly including ICM from the shaft to the cap. ECM shows no codes, car starts, idles like crap, refuses any throttle and dies. With the timing bypass wire disconnected it idles fine but starts loping hard and refusing to go above 1k rpm under throttle. No idea what could be causing it since all ECM wires are fine and it's getting power to the distributor
Car: 1985 Z28
Engine: 305 LG4
Re: Electronic timing advance bad??
Your post in this thread is probably only a tiny part of your problem, and maybe not even actually related. Your other thread you talk about replacing the carb, ECM, and all kinds of sensors. You said it runs worse each new component you add, so you might want to tell people the whole story if you want someone to take the time to help you diagnose it over the internet.
Sounds like you are just firing the parts cannon repeatedly. You can keep doing that and keep getting the same result, or take my advice in your other thread and start a systematic approach to solving the problem(s).
Engine: 305 V8, LG4
I'll have to take some time to really tear into it, but space is limited and I'm not a fan of laying on a hot driveway all day so it'll be a bit
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
My experience with CCC Lg 4s is that even with the ECM missing they will still run well enough to drive-rich, lumpy idle and cloud of black smoke behind if throttle stomped.You need to make sure cat(if still there) is not plugged,there is no major vacume leak.and could run compression test to eliminate engine mechanical problems such as stuck valve,thrown pushrod etc. It is probably a carb problem causing the trouble.
Engine: 305 V8, LG4
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Engine: 305 V8, LG4
Engine: 305 V8, LG4
Car gave me two codes, those being 42 and 55. I understand 42 to be an EST or timing bypass issue, so at least we narrowed that down. But I'm not sure about 55
Engine: 305 V8, LG4
Welp, turns out the distributor was faulty because we replaced it and now it revs perfectly fine, problem solved
