What in the world
Old Feb 24, 2025 | 03:43 PM
FlyBoy06's Avatar
Car: 1983 Pontiac Firebird Trans Am
Engine: 5.0 Crossfire Injection V8
Transmission: Automatic
What in the world
So, this is awkward. Just got this project a month or so ago. Obviously, it doesn’t start. I narrowed it down to the fuel system. Boy, was I right. Pop the trunk and find a cut to the fuel pump has already been made. Go to pull the pump out, and low and behold, there is literally nothing there. What do yall think my best course of action is?? Thanks!
Old Feb 24, 2025 | 04:18 PM
Re: What in the world
That's pretty hyeeenous. Someone set very low standards for their work and then failed to even come close to achieving them.
Looks kinda like Cletus and Billy Bob were rippin' out all that computer s*** and slappin' a carb on it. Looks in fact, by the amount of rust on the hose clamps and whatnot, that they did this A LONG time ago. Maybe it even ran like that for a few years.
Maybe... get a fuel pump and put it in there? After dealing with all the rust of course. Depends greatly on what induction system you are putting on it. The CeaseFire will need a pump obviously; a carb setup really only needs the hose in the tank (which needs to be continuous-immersion rated, which that there is NOT) and a filter on the end to keep out the crusties.
Old Feb 24, 2025 | 04:23 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
PO really screwed that up! Just wow! Are you still running the Cross Fire Injection? If so, there has to be an add-on pusher pump somewhere in-line on the fuel supply side. If the car is converted from CFI to Carb, there is again an add-on pusher pump or someone bolted on a regular fuel pump on the block. Crawl under the car and look at the fuel lines.
What would I do? I would buy a new sending unit (since by the looks of it the gas gauge is not working), and either add the correct fuel pump for the CFI or a L69 pusher pump. Then weld up the hole in the trunk (after pulling the old fuel tank), find and eliminate the pusher pump, but if the car was converted to carb leave the regular fuel pump on the block.
Old Feb 24, 2025 | 05:20 PM
FlyBoy06's Avatar
Wow. Ok. Thank you guys! So, it is a crossfire still. I really don’t know what the PO was thinking when they did whatever they did to the fuel pump lol. Here’s a pic of the fuel line (or at least what I think is the fuel line, right after it drops down below the tank)I noticed that one of those lines looks cut?
Old Feb 24, 2025 | 05:23 PM
FlyBoy06's Avatar
I thought I would add a pic of the engine. It’s gonna need a lot of work, more than I probably should have released. I have the intake off in that pic.
Old Feb 24, 2025 | 05:45 PM
ACebell's Avatar
Transmission: TH350
Axle/Gears: 323
Pictures are always better than words; and by the looks of them what Sofa said was correct. The Red thing on the passenger side frame rail is the pusher pump. That is what "Cletus and Billy Bob" added to get fuel to the Cease Fire Injection (haven't heard that in years). The disconnected line that you provided the picture of was probably the fuel return line. You have a big mess on your hands. This is decision time, and it comes with cost. What are your intentions for this bird? Factory stock or LS swap (joking - maybe not). That entire fuel system from the tank to the TBI units needs to be replaced (including the tank), just to get stable fuel introduced into this system in my humble opinion (which means nothing to anyone else). Are you attached to the CFI? Do you want to swap out for CARB? By tossing money at the problem and time might not be the best option if you plan on upgrading later...
Old Feb 24, 2025 | 10:07 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I'd pour gasoline all over it and throw a match on it and watch it burn to the ground.
Old Feb 24, 2025 | 10:53 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
That Crossfire setup looks pretty haggard. They don't have a great reputation. There was a guy on YouTube once, ran a channel like Crossfire Garage or something. He was really into it, his car almost completely ran for tens of dozens of miles. Started having problems keeping them in sync. Needed parts that were hard to find. He ended up swapping to TBI which actually worked correctly and renamed the channel.
The point is, since you're in it for a fuel pump, now would be a great opportunity to choose something more reliable and easier to live with for an induction system.
Old Feb 25, 2025 | 08:38 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Originally Posted by FlyBoy06
Wow; that is a level of hackitude rarely seen on this website, and believe me, we've seen some. At least it looks like it didn't take a whole lot of diagnosis to figure out the problem(s).
As already stated, that will be determined by what you plan to do with the intake / fuel system.
Geez................
Old Feb 25, 2025 | 09:42 AM
FlyBoy06's Avatar
Thank you guys for your insight. I really do appreciate it. I’m a high school student, and this is my first project car, and it looks like I’ve probably made a poor choice in choosing this one😂. I was originally going to buy and import to work on, but decided to give American a try. Well, here I am. So, my options appear to be:
Completely rehaul the fuel system, and most likely delete the CFI system
Or
Get rid of this one and try again on a better platform.
Again, thanks guys!
Old Feb 25, 2025 | 09:44 AM
FlyBoy06's Avatar
Just for fun, here’s a pic of the car😆
Old Feb 25, 2025 | 09:45 AM
Yeah the old Crossfire system was pretty much the absolute outer limits of what was electronically possible, in 1979 or 80. Needless to say, everything about it has been supplanted since then. Even the late 80s TBI system, which it's possible to almost DROP-IN DIRECTLY replace the problematic electronic parts of CFI with, is VASTLY superior to the rev 0 TBI that Crossfire was merely 2 of. In fact that's one of the upgrade paths people used to take back when anybody was still bothering to try.
Then of course, that doesn't begin to address the worst shortcomings of CFI; which if you're not already familiar with, you'll discover when you take off the intake, turn it upside down, and look at the ports.
I'd strongly recommend NOT trying to revive that CFI as-is. That one looks like it's enjoyed WWWWWWWAAAAAAAAYYYYYY too much sodomy to be brought back to life successfully. Time to swap to something else. Not necessarily a carb; butt that's certainly one of the options.
The cut hose is probably the tank pressure release. If so, would have gone to the "UFO" valve. Butt that's only a guess, since Cletus might have taken his box cutter to almost ANY of them and considered it A Good Idea. There's just NO TELLING what people like that might do to a car thinking it's an "improvement".
Old Feb 25, 2025 | 09:51 AM
FlyBoy06's Avatar
That is good insight😂. Ok, so here’s the question I have now for yall: What would you suggest for a good (and, of course, fun) project car.
Old Feb 25, 2025 | 10:22 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
What you end up with depends on your budget, and the crossroads here is largely whether you want to go with a carburetor or fuel injection. One wants about 5psi of fuel pressure, the other wants 43 or 58psi so the fuel pump should match.
Carb is probably cheaper overall, fuel injection gives you modern convenience. I did a TPI swap for a little under $2k ecm included but I got the majority of the components for free.
This car is also a good candidate for an LS swap which sidesteps the issue entirely but that'll end up costing twice what just an induction system will.
Old Feb 25, 2025 | 10:31 AM
FlyBoy06's Avatar
Yeah, I have considered maybe doing an LS swap, as opposed to buying a whole new car. I just don’t know what quality of car you would want to have in order to make the swap worth it.
Old Feb 25, 2025 | 10:38 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
No one can answer that question but you.
Old Feb 25, 2025 | 10:39 AM
FlyBoy06's Avatar
But man, I can still use some pointers as to what to be looking for in a good candidate.
Old Feb 25, 2025 | 10:42 AM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
For what? A show car? A road race car? A daily driver?
If you are looking for a daily driver I would get something 40 years newer.
Old Feb 25, 2025 | 10:52 AM
FlyBoy06's Avatar
Facts😂. I was just looking for a car that is cooler than my 04 subi 😎. Well, we’ll see what I do with this one.
Old Feb 25, 2025 | 10:56 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
A good candidate is a car that you can complete and get on the road. That depends mostly on your financial situation, access to tools, and mechanical aptitude.
If that car has all its parts and isn't too rusty, it's probably fine. We all know the CFI took it out early so the motor is likely good. If a motor swap is intimidating, just go for the pump and intake and get it running.
Old Feb 25, 2025 | 11:26 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Lore.
The CFI systems does not come out of synch normally, unless it's messed with. And even if it does, slightly, it doesn't affect operation. TBI parts are not hard to find; it's a "Tech 4 TBI", if which there were 100's of thousands made.
Now, that's not "hearsay"...or my friend's-buddies-dad's car. I actually owned one for over a decade, drove the wee out of it, put three engines in it...CFI part always worked great. It ain't hard/complex or "mystical"...it's a basic, speed density, TBI system.
As for that fuel pump abortion, I'd rip everything out that the PO did, put in all stock fuel pump parts, lines, hoses, etc. then I'd weld the floor pan back together, grind/prime/paint it.
Old Feb 25, 2025 | 12:17 PM
FlyBoy06's Avatar
I do like that idea. I think this car is such a cool piece of history. It’s a 25th Daytona edition, with Ricardo seats, and the original color was the Daytona white with graphics. I think it would be pretty cool to restore it back to its original condition.
Old Feb 25, 2025 | 12:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
recardo seats 😆, spell check got that good
Old Feb 25, 2025 | 12:37 PM
FlyBoy06's Avatar
Thank you IPhone 🤣
Old Feb 25, 2025 | 12:42 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
recardo seats....
"Lucy, you got some esplainin' to do!"
Old Feb 25, 2025 | 02:17 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Lore.
Guilty as charged, but you're right all this car needs that we know of is a fuel pump, and then we can find out if it still crosses the fires.
Old Feb 25, 2025 | 04:15 PM
Engine: LT1, L400
crosses the fires.
LOVE IT!! That was hilarious!!
Old Feb 25, 2025 | 04:17 PM
FlyBoy06's Avatar
Sounds very ritualistic 😂
Old Feb 25, 2025 | 04:18 PM
FlyBoy06's Avatar
Well, if anyone’s interested in a project car, hit me up 😉
Old Feb 25, 2025 | 05:15 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
This car is actually a somewhat desirable car to some people. It may not be hard to get going once the fuel pump fiasco is fixed and the sardine can is properly closed. Another option is a standalone EFI. An edelbrock pro flo xt would fit in there easy. Add a fuel pump and you're all set.
the car looks pretty straight. You could also sell
it.
If you have an 04 Subaru, you have something that could be really reliable. Those kind of go forever. An 83 TA will never be an ideal daily driver. But it could be pretty easy to make fun.
Old Feb 25, 2025 | 05:37 PM
Engine: LT1, L400
I'd love to have another CFI car. I don't care about the "Daytona/Recaro" part of it (though I'd respect that aspect of it).....
Old Feb 25, 2025 | 05:45 PM
FlyBoy06's Avatar
All true things. The subi only has 60k miles on it so I’m not worried about needing a daily. If I could get this one running, I think it could be pretty sweet. Also, another thing. Is it common to have true duel exhaust on one of these? It appears as if it has long tube headers also…
Old Feb 25, 2025 | 05:59 PM
Airwolfe's Avatar
Put it on Facebook Marketplace or Craig's List and sell it for what ever you can get out of it. Get out while you can.
You will never have any idea how much time, money, effort, and heartache I just saved you.
I promise you dude cut bait and run while you still can.
As a 17 year old high school student you won't be able to understand what I'm telling you until you are at least 30 years old probably.
Old Feb 25, 2025 | 06:07 PM
Car: 82 TA
Take some pics of the exhaust. Headers and duals aren't stock. Duels on these cars can be a disaster depending on how it's done.
Old Feb 25, 2025 | 07:02 PM
FlyBoy06's Avatar
For sure. I’ll be taking pics to list tomorrow. I’ll drop them here for yall.
Old Feb 26, 2025 | 05:36 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Do you have anyone that knows what they're doing or are you in it by yourself? Easiest way to get on the road would be to drop the tank and stitch that sardine can back together. Get a replacement tank and sending unit for a carb'd car, should hook up to the existing lines. If not, replacement lines are cheap. Pop the crossfire intake off and sell it to pay for a Chinese aluminum intake and get a 600cfm carb. The block should have provisions for a fuel pump.
Old Feb 26, 2025 | 07:57 AM
Engine: LT1, L400
Originally Posted by exiled350
Get a replacement tank and sending unit for a carb'd car, should hook up to the existing lines. If not, replacement lines are cheap. Pop the crossfire intake off and sell it to pay for a Chinese aluminum intake and get a 600cfm carb. The block should have provisions for a fuel pump.​​
That's definitely NOT the easiest way.
Old Feb 26, 2025 | 08:08 AM
exiled350's Avatar
Certainly not easier than having it towed to the crusher, but way easier than a full engine swap or figuring out what the previous owner did and undoing it.
Old Feb 26, 2025 | 08:24 AM
"True dual" exhaust is known to be a MAJOR can of worms on these cars. Notoriously difficult to make it fit and work right. There simply isn't enough space in certain places. Either the craftsmanship has to be exquisitely excellent, kinda like that fuel pump installation and tank modification are, or it ends up being a low-hanging disaster that drags on driveways and tears itself off and actually flows worse than an off-the-shelf good-quality single kit.
Long-tube headers are the same way. The regions that they have to route through are just too small. There are only a couple of such options available, for that reason; they are expensive, and installing them tends to be ... invasive. Headers for any other chassis don't fit right, and if somebody took that route, there's no telling what they did to graunch them in there. Although, looking at the fuel pump installation and tank plumbing, I can guess.
Frankly, I'd have to see a photo of the car from underneath, to believe that it ACTUALLY has either of those things. And if it does, more than likely (again looking at the fuel pump installation and quality of tank modification) it needs to be ripped completely off and redone ANYWAY.
One thing that hasn't been mentioned yet is the transmission. Since CFI only came with auto, it was a 200C, originally; one of the steamingest buckets of elephant plop GM ever released. It was VERY popular back in the day to replace that with a Turbo 350, which is a direct drop-in, except for the torque arm, for which the 350 never had provisions. There used to be solutions for that, some better than others; some quite good in fact, and some, well, NOT. I'd need to see photos of it to be able to tell how they did it, and I'm betting that it either still has the 200C in it (in which case it's fornicated and that's probably why it was for sale), or that the 350 is installed with the same degree of professionalism and pride of workmanship and overall show-quality excellence as those other things we've already seen.
The more you tell us about this thing, the more I agree with this. If what you're telling us is true, you've got a mess on your hands that you'll probably NEVER be able to de-hackify to the extent that you can actually DRIVE it. Make it somebody else's problem. Trust me when I tell you, there's ALWAYS A Greater Fool out there somewhere, no matter how bad you think something is; might take awhile to find em, butt THEY'RE OUT THERE. Send it down along that line and don't regret it. You WILL regret keeping it and trying to "restore" it. It's too far gone to become "a nice car" ever again, at least at any kind of cost that could compete with just going out and buying a car that isn't pre-trashed. You'll end up with an UNBELIEVABLY expensive useless garage ornament, AT BEST. A giant money pit that swallows whatever you throw down it and begs for more at every turn.
Old Feb 26, 2025 | 09:00 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
^^^^ THIS.
I'm just curious to view the workmanship involved in putting true duals on this 3rd gen.
Old Feb 26, 2025 | 09:20 AM
FlyBoy06's Avatar
So
Right before the super turbo mufflers
Coming down from behind the rear axle
Back pipe
Back pipe
Sorry a bit tight in here
So, here it is.
Old Feb 26, 2025 | 09:55 AM
  #42
So, not long-tubes since the driver's side collector would exit somewhere behind the bell housing thereby rendering the crossover in the stock location under the oil pan impossible, and about 2" or maybe 2¼" pipe...
It's a CONSIDERABLY neater installation than I was expecting, though, except for the 10 lbs or whatever, of U-bolts. Most of the crush bends aren't even too dreadfully brutal.
The car has definitely been sitting around for awhile. Any idea why that is?
Old Feb 26, 2025 | 10:02 AM
  #43
FlyBoy06's Avatar
So, all the history I know of this car is that it was originally white with Daytona decals, owned by someone here in Southeast Idaho, it eventually made its way to Utah, where it was painted with flames (which you can kinda see under the purple paint), then some highschool kid here in Blackfoot, Idaho, bought it as a project car in about November of last year, but then went on a mission. At that point, it was sold to me. And, now it sits here in Pocatello, Idaho.
Old Feb 26, 2025 | 10:04 AM
  #44
FlyBoy06's Avatar
[QUOTE=exiled350;6554747]Do you have anyone that knows what they're doing or are you in it by yourself? Easiest way to get on the road would be to drop the tank and stitch that sardine can back together. Get a replacement tank and sending unit for a carb'd car, should hook up to the existing lines. If not, replacement lines are cheap. Pop the crossfire intake off and sell it to pay for a Chinese aluminum intake and get a 600cfm carb. The block should have provisions for a fuel pump.
​​A am pretty much doing it by myself. My dad is helping a little in any way he can but we both have minimal project car experience
Old Feb 26, 2025 | 10:49 AM
  #45
exiled350's Avatar
Well that's gonna be one hell of a way to learn. Thankfully there are tons of resources available online and most parts are easy to source. I got pretty lucky, my dad was a mechanic so I learned all this stuff young. Now I'm somewhere between a mechanic, engineer, and software developer and my kid had been wanting a project car since she was like 14. I know all about other peoples projects and what they're capable of, that's how she ended up with a $12k IROC instead of a $6000 look at all the upgrades screaming deal. Live and learn, gotta start somewhere.
Old Feb 26, 2025 | 10:54 AM
  #46
FlyBoy06's Avatar
It’s true man! I’ll be going to school for aircraft maintenance so hopefully I can learn something from that too lol.
  #47
Vader's Avatar
The photos are not completely revealing, but those that are provided do not show an oxygen sensor screwed into one of the pipes. Then again, that's often on the pilot's side, and the photo showing the insulation on the intake doesn't reveal that angle. That would make operation of the EFI pretty tough.
The photo does seem to show a mechanical fuel pump and inline filter, so the spaghetti pickup in the tank is at least a little more viable (short-term).
Old Feb 26, 2025 | 10:58 AM
  #48
FlyBoy06's Avatar
Overall, it appears that all the emissions systems have been removed, or at least that what it appears like to me.
Old Feb 26, 2025 | 11:13 AM
  #49
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I'm with Tom, that car looks pretty savable to me. Of course, he changes induction systems more frequently than I change my underwear and I'll pull a motor in a gravel driveway so maybe we're both crazy.
Old Feb 26, 2025 | 12:31 PM
  #50
Car: 82 TA
Wow, that exhaust is much better than I figured.
Id think about what you're up for. Do you wanna take the time to figure out if the crossfire works or do you wanna move on from that system and do something else. I wouldn't rush dropping the tank till you know what direction you go. If you don't need emissions a standalone efi setup is the move and pretty simple. If you want to mess w the crossfire, you need to see if it fires over and then will it run. Who knows, you may be able to stick a fuel pump in and it will run fine. I doubt it but also doubted the quality of the dual exhaust!
