Oil leaking and pressure drops when hot
Old Mar 1, 2025 | 08:39 PM
m1902saber's Avatar
What the title says. I have an '86 base model Firebird with the original 2.8l v6 in it. This issue has been going on for about a month or two and I thought it could have been an issue with the sensor, but I replaced that today and it's still doing the same thing. Pressure starts out fine, in the 40-50 range but slowly drops down to about 10 lbs when the engine warms up to temp, and it starts idling low too. Also, there's a small amount of oil leaking from the pan, I'm assuming that's the just the gasket because it hasn't been replaced in 40 years. Anyway, I'm thinking this could be a failing oil pump, but I want to hear everyone's thoughts here. I can provide more info if needed.
Old Mar 2, 2025 | 11:04 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Oil leaking and pressure drops when hot
Probably a worn oil pump-aluminum pump body on 60*v6 -shaft hole wears and lets pump gears rub housing and wear too much clearance
blackbeauty89
May 27, 2014 10:36 AM
justgetacamaro
Aug 27, 2010 08:22 PM
jg2006
Nov 22, 2008 04:43 PM
94 Junkyard Dog
Aug 31, 2007 01:02 PM
subliminal
Apr 3, 2007 11:11 AM
