Thicker valve cover gasket?
Old Mar 20, 2025 | 03:39 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
GM and their legendary ***** changes sizes once removed has reared it's ugly head. I've had proform center bolt valve covers for two seasons now with no issues. I had them off to do a valve adjustment and the driver's side #1 cylinder rockers are tapping the cover. Makes no sense. I've shifted them, tried everything and if the bolts are just barely tight the tapping stops. If I torque them down there's contact. I don't get it but whatever. Maybe I bent them a bit, I have no idea. Regardless, is there a thicker one available? Mine are the blue felpro rubber ones.
Old Mar 20, 2025 | 03:59 PM
Re: Thicker valve cover gasket?
How about using 2 of them?
Yes I've done it before with other VCs.
Old Mar 20, 2025 | 04:11 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Was thinking of that with those same blue ones. You don't get leaks from in between or are you siliconning them together? There's no pressure so I guess they likely won't leak
Old Mar 20, 2025 | 04:54 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Fel-pro makes an ultra premium laminated steel and cork one. IDK if it is any thicker but it is more expensive than the blue ones.
Old Mar 20, 2025 | 05:04 PM
I had some Vette aluminum VCs (perimeter-bolt) that needed that to sit clear of Loly-Locks on top of longer valves and longer push rods. I used the SOOOOOOOPER THICKKKKKKK Victor-Reiz ones for awhile butt it just didn't quite get the job done. 2 of the Moroso blue ones though, Somewhat like you described; a steel core encased in blue goo.
I used gorilla snot, putting it on between the VC and the 1st gasket and between the 2 gaskets. In both places I put it on both their surfaces and let it set up for a half hour or so before assembly. Then used grease between the 2nd gasket and the heads.
Old Mar 20, 2025 | 05:17 PM
kheiron's Avatar
Car: 1990 IROC-Z
I just installed these with proform covers on my 350TPI and they are indeed significantly thicker.
Old Mar 20, 2025 | 05:47 PM
Airwolfe's Avatar
The Fel-Pro CORK-LAM valve cover gaskets are .250 thick and the Fel-pro blue rubber one are .181
Fel-Pro Performance CorkLam Valve Cover Gaskets - 1648 - Summit Racing
Old Mar 20, 2025 | 06:51 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks for the info. So two blues are just under 3/8 of an inch. I already have those so I'll silicone two together and see how she goes.
Old Mar 22, 2025 | 07:42 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Seems to have done the trick. I siliconed two Felpro VS50088R blue gaskets together and I now have the clearance. No idea what the hell happened that I needed the two, but nonetheless they are working. Just needed to be careful on centering the cover because with them being raised a bit they no longer self locate on the head.
KYLE87
Mar 15, 2008 04:35 PM
TKO500
Jun 5, 2006 11:22 AM
88GTAinRI
Sep 27, 2003 07:12 AM
twiztidz28
Jun 28, 2002 02:56 PM
