Stall and dies
Old Mar 31, 2025 | 12:56 PM
lolodenimes's Avatar
Stall and dies
Hello!
I'm restoring a 1990 RS 5.0 and unfortunately since i have it, the car stall and dies when warming up...
I've looked all the forums and video but nothing works!
I've already changed :
Fuel pump, gasoline filters, spark plugs, ignition distributor arm, ignition head, spark plug wire, ignition coil, rebuilt kit throttle body, IAT sensor, TPS sensor, thermostat, ignition control module, oil temp sensor, oil pressure sensor, motor temp sensor, O2 sensor.
Yes that's a long list and i probably miss some components! But still stall and dies...
PLEASE I NEED HELP.
Old Mar 31, 2025 | 01:34 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Stall and dies
It's rough trying to fool with 80's and 90's American cars in Europe with getting parts and finding mechanics to work on them.
Old Mar 31, 2025 | 01:56 PM
Re: Stall and dies
Oh sure it is...
I mainly bought all my parts from rockauto
Old Mar 31, 2025 | 08:24 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Stall and dies
Stick or auto? Tbi or tpi?
Old Apr 1, 2025 | 01:15 AM
Re: Stall and dies
my bad, auto tbi
Old Apr 1, 2025 | 06:15 AM
gp90gta's Avatar
Car: 1990 GTA
Re: Stall and dies
Okay so I’ll assume the car runs well when warmed up, so let’s start with the obvious, you need air fuel and spark and as long as the valves and pistons aren’t leaking sealing it will run.
Being auto there is one other thing to look out for and that’s the lockup converter, they can sometimes lock when at idle dragging the engine and stalling it.
I also remember an issue with some of the older gm ecu’s the solder would crack and cause all kinds of crazy issues.
I would start with
1. Check to see if your losing ignition, easy all you need is a timing light.
2. Check see if your losing fuel, pull the air cleaner and have a can of ether/starter fluid ready and spray while it’s trying to stall.
3. If your not losing fuel or spark unbolt the torque converter and retest.
Old Apr 1, 2025 | 06:41 AM
Re: Stall and dies
I thought i already said it but the car runs well when cold (a bit too high in rpm) and when warming up (like 4 min) , it slowly decrease in rpm and stall then dies, all of it when in park.
Old Apr 1, 2025 | 07:41 AM
gp90gta's Avatar
Car: 1990 GTA
Re: Stall and dies
Okay so when it’s at operating temperature it won’t stay running?
All three that I mentioned still apply.
Old Apr 1, 2025 | 07:54 AM
Re: Stall and dies
That's right.
I'm going to buy a timing light to test but i don't think there will be issues on that part.
For the fuel, everything is ok.
And i suppose that the torque converter should not be engaged while in park?
Old Apr 1, 2025 | 09:45 AM
gp90gta's Avatar
Car: 1990 GTA
Re: Stall and dies
Correct, a bad converter usually only stalls the car when in gear but I did once have a car at the shop with a stalling issue because of it even in park.
edixon24
May 2, 2022 08:15 AM
Mr Froman
Oct 16, 2009 07:58 PM
wconn1979
Sep 13, 2007 02:45 AM
19doug90
Aug 13, 2004 06:37 PM
david auster
May 8, 2002 08:48 PM
