Pushrods too long?
Old Apr 29, 2025 | 07:14 PM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Pushrods too long?
Looking for a little consensus from the more experienced engine guys here. I just recently swapped lifters in my small block to a reduced travel (.093”), roller lifter. I’m using the mid-lift method on that straub technologies YouTube video to get my pushrod length. Thing is, I’m getting 7.75” for my length! WAAAAAY longer than anything I’ve ever used before. Johnson 2116SBR lifters and 1.52:1 Comp Ultra Pro Mags for rocker arms, 7/16” studs and .353” lobe lift. Coming from Morel 5372’s I was using a 7.5” pushrod. It just seems so long, is this not unusual for a SBC?
Old Apr 29, 2025 | 08:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Pushrods too long?
Are you using an OEM or aftermarket block? Same goes for the heads. Are you running stock or aftermarket heads with a thicker deck?
Old Apr 29, 2025 | 08:50 PM
Engine: 383 SBC
I wish I could afford an aftermarket block! Instead I’m using an 880 block that’s 0 decked and AFR #1038 heads.
Old Apr 30, 2025 | 05:22 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
I ran into this over the winter. Apparently there is no too long or too short, it's what works right. I had 7.800 pushrods and they were riding the intake side of the valve really bad. Using the midlift method, an adjustable pushrod, and check springs we came up with 8.200. The geometry is way better now.
Old Apr 30, 2025 | 04:52 PM
Engine: 383 SBC
I was able to bring home my calipers from work today. Can’t get a perfect measurement on the Johnson lifter but just measuring the body of the lifter alone is almost .250” shorter than the advertised cup height for the outgoing lifters. That definitely accounts for the large change. Guess I’ll measure again and get what I need.
m300slr
Jan 31, 2022 06:24 AM
cooljo39
Apr 1, 2011 02:47 PM
customblackbird
Aug 30, 2008 01:59 PM
327_TPI_77_Maro
Mar 19, 2008 02:24 PM
jrg77
Mar 20, 2005 08:28 PM
